Hi Ted,
Thanks for the tip.
FYI - I added these assembly references to the form too.
- Epicor.Mfg.AD.ChgLog
- Epicor.MFG.BO.ChgLog
- Epicor.Mfg.IF.IChgLog
Thanks for the tip.
>> You can try this bit of code and hook it to a button click event.I tested and it worked well.
>>Dim edvRes As EpiDataView = CType(oTrans.EpiDataViews("Resource"), EpiDataView)
>>Dim resIdent As String = edvRes.dataView(edvRes.Row)("RowIdent")
>>Dim chg As Epicor.Mfg.UI.App.ChgLogEntry.ChgLogArgs
>>chg.Start(oTrans, "Resource", resIdent, True)
>> I Found the example in this post:
>> http://tech.groups.yahoo.com/group/vantage/message/95340
> Hope it helps,
> -Ted
> From: b_ordway <cooner_55421@...>
> To: vantage@yahoogroups.com
> Sent: Friday, December 28, 2012 1:11 PM
> Subject: [Vantage] Re: Vantage 8 - Way to see change history on an Employee record
> Hi Jeanette,
> Do you know if your system set up includes a BAM to create the change logs? You may need to set that up first.
> EmpBasic table BAM for a "Shop Employee".
> (or User table BAM for a "User Account").
> The fields to log changes would be specified in the BAM too.
> You can then build a BAQ as mentioned.
> ChgLog Table
> - Criteria: TableName = EmpBasic (or User)
> - Changes listed in field: ChgLog.LogTest.
> Like you, I've noticed that not all forms provide access to the change logs.
> I've never tried but maybe someone else on this forum knows how to add them with a customization?
> --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > Jeanette,
> > In Epicor 9 you can create a BAQ and look in the ChgLog table. I'm not sure if V8 has the ChgLog table but if it does you should be able to find what you're looking for.
> > Hope it helps,
> > -Ted
> >Â From: redden.jeanette <redden.jeanette@>
> > Sent: Wednesday, December 26, 2012 1:00 PM
> > Subject: [Vantage] Vantage 8 - Way to see change history on an Employee record
> >Â
> > Need your expertise please.....I am looking to see who made an update on an employee record. I know job tracker has a change log icon that you can see changes, but I do not see this option on the employee record. Is there a log or another method to be able to see this please?
> > Thank you!
> > Jeanette
