Vantage 8x: Anyone ever use the Exective Dashboard 'Supplier Per
I tried it but the format didn't make much sense.
An Epicor employee once told me it was more for show than anything practical.
I ended up disabling it in menu maintenance.
Anyway, the instructions you have look correct to me.
If you scheduled the process and give it time to complete I would expect you should see something when you refresh.
--- In vantage@yahoogroups.com, "dgodfrey_amc" <dgodfrey@...> wrote:
> I have been trying to get it to show data to no avail. I call Epicor Support and they gave me following solution. I still can not get data. So I am wondering if anyone else has used it.
> Dan
> Page 13103mps
> PROBLEM DESCRIPTION:
> SV Supplier Performance Dashboard is not returning data, blank grid. Or the data is not correct, appears old, outdated.
> VERSION: 8.03.409a
> PROBLEM RESOLUTION:
> Follow these steps to correct.
> 1. Executive Analysis > Business Activity Management > General Ops > Schedule Process Set.
> 2. Select zSVSupplierPerf for the current company ID and then click Submit on the toolbar.
> 3. Allow it to complete, monitor its progress in the System Monitor located under System Management > Utilities. It will start as an Active Task while it runs and move to the History Tasks tab when it is done.
> 4. Click the Refresh buttons in the top toolbar in the Dashboard itself.
> 5. Make sure all open PO Lines and Releases have their Due Date field populated with a date. If this date is left blank, no data will appear in the above dashboard for this item.
Dan
Page 13103mps
VERSION: 8.03.409a
PROBLEM RESOLUTION:
