Vantage - Adding Buttons to Dashboards
Did you have any luck with this?
Sincerely
Jose C Gomez
http://www.josecgomez.com
On Mon, Apr 6, 2009 at 7:39 AM, Chris Thompson <chriselectrix@...>wrote:
> Hi,
> I have created a Dashboard, that required the refresh button to be pressed
> to refresh the data, there is also a Tracker part of the dashboard that
> required the Clear button to be pressed to clear the search data.
> Does anyone know how to create the following buttons to be added to a
> dashboard -
> 1) A button that can be added to the search part of the dashboard that will
> perform the same operation as the 'REFRESH' button
> 2) A button that can be added to the search part of the dashboard that will
> perform the same operation as the 'REFRESH ALL' button
> 3) A button that can be added to the search part of the dashboard that will
> perform the same operation as the 'CLEAR' button
> Any helo would be greatly appreciated.
> Thanks,
> CHRIS THOMPSON
Hi,
I have created a Dashboard, that required the refresh button to be pressed to refresh the data, there is also a Tracker part of the dashboard that required the Clear button to be pressed to clear the search data.
Does anyone know how to create the following buttons to be added to a dashboard -
1) A button that can be added to the search part of the dashboard that will perform the same operation as the 'REFRESH' button
2) A button that can be added to the search part of the dashboard that will perform the same operation as the 'REFRESH ALL' button
3) A button that can be added to the search part of the dashboard that will perform the same operation as the 'CLEAR' button
Hi,
CHRIS THOMPSON
