Jody,
Just one person's opinion ... NO ...
Not until you know exactly why this software needs to be on your server. Is
the Sonitrol system network based ? What does it use for a database and
what does it use for basic communications. etc etc etc
If you install this on your server and it screws up the Progress config what
then ? Last I knew Progress and MS-SQL would not run on the same server. (
for instance ) This may be more then a performance issue ...
This is a great case for having more then one server.
As in:
1 server for Primary Domain Controller / print-server / WINS / etc
1 server for Vantage
1 very small server for all the weird junk like this package
I would take a P-200 with 64 meg of RAM and one drive and make it a server
just to run this program and other "Small" stuff. Got an old PC laying
around with these kind of specs ? If not, for $ 1,000 - $ 1,200 you can buy
the smallest desktop that DELL sells and load NT-Server on it.
At any rate - Good Luck !!!
Todd Anderson
Sent: Monday, October 23, 2000 3:21 PM
To: vantage@egroups.com
Subject: [Vantage] Vantage and Sonitrol
** High Priority **
Does anybody else out there use the Sonitrol security system (for guarding
access to all doors)?
The plant manager wants me to load the software to manage and run reports
for this system on my NT server and I am just wondering if that could have
any impact at all on the performance of Vantage........
Thanks!
Jody@...
eGroups Sponsor
<http://click.egroups.com/1/9639/13/_/411782/_/972332666/>
<http://adimg.egroups.com/img/9639/13/_/411782/_/972332666/TargetGifts468x60
2F.gif>
<http://www.egroups.com/files/vantage/>
As in:
Todd Anderson
** High Priority **
Thanks!
Jody@...
eGroups Sponsor
2F.gif>
