Vantage Client on Server?
Gary,
It should work for 4.0 also. We have done it since 3.0, but we skipped
4.0.
Troy
Sent: Thursday, May 01, 2003 11:15 AM
Subject: RE: [Vantage] Vantage Client on Server?
Troy,
Does this work for ver4.0 too?
Gary Polvinale
Sent: Wednesday, April 30, 2003 9:58 PM
Actually, we use mapped drives on the server client install, just like on
a
regular client install.
Here is the steps I used to install the Vantage client on the server.
1. Map the drive like you do for a regular client to the epic5x folder.
2. Double-click the V:\vantage\vantageclientsetup.exe
3. Follow the steps as you would a regular install with ONE EXCEPTION.
-When it asks you to install Progress, SAY "NO" (don't check the box).
Progress was already installed when you installed Vantage on the server,
so
you don't need to install the Client version of progress.
4. As you continue through the Vantage portion of the install, you can
select your icons, etc. as you normally would.
Vantage should work just as it does on a regular client.
Troy Funte
Liberty Electronics
Sent: Wednesday, April 30, 2003 6:31 PM
Yes...this causes no problems. Just remember to access Vantage via the
local drives instead of the mapped drives.
Dan Tisone
Operations / IT Consultant
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Sent: Wednesday, April 30, 2003 1:53 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Vantage Client on Server?
Hello all,
Can I install the Vantage client on the vantage server? Will that cause
any problems?
Jasper
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
and
have
Hello all,
Can I install the Vantage client on the vantage server? Will that cause any problems?
Jasper
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Hello all,
any problems?
Jasper
Actually, we use mapped drives on the server client install, just like on a
Progress was already installed when you installed Vantage on the server, so
Troy Funte
Liberty Electronics
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Hello all,
any problems?
Jasper
Troy,
Gary Polvinale
Troy Funte
Liberty Electronics
Dan Tisone
dan.tisone@...
(949) 440-3685 x148
Cel (714) 227-4173
Hello all,
any problems?
Jasper
