Vantage client problem on Terminal Server
Thanks for the suggestion, Chris - wow, I was at high school when hard drives still weren't standard!! I will forward your snippet of experience to our tech. support, it just might prove to be the key. Thanks again :-) :-)
++ Andy Watts
++ Ripley Engineering Ltd
++ Tel: 01256-473940
++ Fax: 01256-479991
++ mailto: andy@...
>>> Date: Mon, 12 Aug 2002 07:57:09 -0700
>>> From: "Chris Robisch" <crobisch1@...>
>>> Subject: Re: Vantage client problem on Terminal Server
>>> Before PC's had hard drives standard, Novell Netware used to map the C:
>>> drive to a Server drive to allow large applications that assumed a client
>>> hard drive to run. They would reserve V: to Z: for the client hard drives.
>>> I've run into problems using V: for Vantage on Citrix Servers, assuming they
>>> were trying to be compatible with old Netware. Changing V: to U: worked.
>>> HTH.
Hi everyone,
I have a problem running the Vantage client on NT Terminal Server, and wondered if any of you guys had experienced anything like it. I would really appreciate any thoughts on it, it's driving me nuts!!
Here is an extract of my email to support over here in the UK:
System Info:
Server OS - NT Terminal Server, Service Pack 6
Client OS - Terminal Server Client session
Vantage - v5.10.123
Progress - v9.1C
Problem Symptoms:
One of two things occur when the user attempts to start the Vantage client;
1- The cursor changes to an egg timer, nothing appears on the screen, and the server CPU utilisation rises to 100% and remains there until the "vantage.exe" client process is manually killed.
2- The Vantage splash screen briefly appears, then the login box appears, seemingly as normal. When the user attempts to type in a user name and password, no keystrokes seem to be accepted - the boxes remain empty. meanwhile, the server CPU utilisation has risen to 100%, and remains there. Normally, the login box accepts keystrokes after 10-20 minutes, but sometimes it does not at all. If the "vantage.exe" process is manually killed, the login box accepts keystrokes.
Conclusion:
It would seem that the login box (part of the "prowin32.exe" process) does not function past a certain point until the parent "vantage.exe" process has terminated. However, the "vantage.exe" process is either taking a very long time to terminate, or is not terminating at all, causing the apparent freeze-up of the Terminal Server session.
Thanks very much in eager anticipation!!
++ Andy Watts
++ mailto: andy@...
Hi everyone,
System Info:
Vantage - v5.10.123
Progress - v9.1C
Problem Symptoms:
Conclusion:
++ Andy Watts
++ mailto: andy@...
HTH.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, August 12, 2002 3:30 AM
Subject: [Vantage] Vantage client problem on Terminal Server
> Hi everyone,
> System Info:
> Vantage - v5.10.123
> Progress - v9.1C
> Problem Symptoms:
client;
> Conclusion:
> ++ Andy Watts
> ++ mailto: andy@...
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
