The only time this field populates with a date is when you are creating a job from scratch...Job Entry>File>New Job. If you use the Planners Workbench in creating a new job fulfilling demand...the create date does not populate.
If you want to track the date in which Jobs are created...you have to setup a BAM on the JobHead table. Then write a BAQ pulling from the ChgLog where the ChgLog.TableName = JobHead
Patty Buechler
Patty Buechler
--- In vantage@yahoogroups.com, "fnaslis" <mirtech2009@...> wrote:
> Something in our vantage configuration has been desactivated.
> when a job is created,
> the creationdate is null in the database. This doesn't happen for the jobs with a name beginning with MRP. In many other tables the creation date is not inserted when a new record is added.
> Do you have an idea on what to change in the config to have the field JobHead.CreateDate updated automatically when a new job is created?
> thanks.
