Vantage - Dashboard Filters
Thanks.
Sent: Tuesday, January 27, 2009 2:16:47 PM
Subject: [Vantage] Re: Vantage - Dashboard Filters
I've made some minor changes to BAQs, and the change was automatic on
my Dashboard without me having to re-import. Other times, I wasn't
sure if it would work since my BAQ change seemed major, so I did re-
add the BAQ to my dashboard.
I don't remember having to re-create filters.
I recommend you first try to re-open the dashboard without re-
importing the BAQ & see if it picked up the new field.
--- In vantage@yahoogroups .com, Chris Thompson <chriselectrix@ ...>
wrote:
> Hi Lynn,
> I've found the solution (well somebody has told me it).
> Create calculated field for
> If ShipDtl.PackNum >= 0 then 1 else 0
> Then filter on the 1 / 0s.
> If I import a BAQ into a Dashboard, then make an alteration to the
BAQ (ie add another field) can I re-import the BAQ into the Dashboard
without losing the filters etc I have in place?
> Cheers,
> CHRIS
> ____________ _________ _________ __
> From: Lynn <lynn.khalife@ ...>
> To: vantage@yahoogroups .com
> Sent: Tuesday, January 27, 2009 2:05:42 PM
> Try PackNum < 1.
> If that doesn't work, then I'm out of suggestions, sorry.
> Lynn
> wrote:
> > Hi Lynn,
> > My PackNum column is completely empty - whereas when my Number
> fields are emtpy they show as 0.00000.
> > If I filter on PackNum = 0, it returns no results as I think it
is
> looking for a PackNum called 0, when it isn't actually called '0',
it
> is acutally ' ' (blank).
> > If I try PackNum = 260 it will display the line for PackNum 260,
so
> the functionality is working but 0 doesn't work to retrieve all of
> the 'blank' PackNums.
> > Do you have any further suggestions?
> > I'm really stuck on this one!!
> > Cheers,
> > CHRIS
> > Sent: Tuesday, January 27, 2009 1:20:39 PM
> > That is correct, you can't use Null with numeric fields because
the
> > numeric field is never empty. It always has either a zero or a
non-
> > zero number in it.
> > What you really want is PackNum = 0.
> > To the database, 0 is the same as 0.00000.
> > Lynn
> > wrote:
> > > Hi,
> > > I am trying to display all orders on Vantage that do not have a
> > Pack Number (i.e. packing has not started).
> > > I have a BAQ where I can view the following tables:
> > > OrderHed
> > > OrderDtl
> > > Customer
> > > ShipDtl
> > > The only information I need to see is the Request Date, Order
> > Number, PackNum, Customer.
> > > I have imported the BAQ into a dashboard and have tried to
filter
> > the PackNum field..
> > > I want to only see the Orders where they don't have a PackNum.
> > > In other word where PackNum = Null.
> > > Apparently I can't use a null value with the numeric..
> > > Epicor suggested comparing it against a Num01 field, but they
> > display as 0.0000 which isn't actually Null.
> > > Does anyone have any suggestions where I can filter the above
> > information based on the Order NOT having a PackNum?
> > > Cheers,
> > > CHRIS
Hi,
I am trying to display all orders on Vantage that do not have a Pack Number (i.e. packing has not started).
OrderHed
OrderDtl
Customer
ShipDtl
The only information I need to see is the Request Date, Order Number, PackNum, Customer.
I have imported the BAQ into a dashboard and have tried to filter the PackNum field.
Epicor suggested comparing it against a Num01 field, but they display as 0.0000 which isn't actually Null.
Does anyone have any suggestions where I can filter the above information based on the Order NOT having a PackNum?
Cheers,
CHRIS
That is correct, you can't use Null with numeric fields because the
numeric field is never empty. It always has either a zero or a non-
zero number in it.
Lynn
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...>
wrote:
> Hi,
> OrderHed
> OrderDtl
> Customer
> ShipDtl
the PackNum field.
> Cheers,
> CHRIS
Hi Lynn,
My PackNum column is completely empty - whereas when my Number fields are emtpy they show as 0.00000.
If I filter on PackNum = 0, it returns no results as I think it is looking for a PackNum called 0, when it isn't actually called '0', it is acutally ' ' (blank).
If I try PackNum = 260 it will display the line for PackNum 260, so the functionality is working but 0 doesn't work to retrieve all of the 'blank' PackNums.
Cheers,
CHRIS
zero number in it.
Lynn
wrote:
> Hi,
> OrderHed
> OrderDtl
> Customer
> ShipDtl
the PackNum field..
> Cheers,
> CHRIS
Create a logic calculation field and do an if that PackNum is Greater than
or equal to 0 then 1 else 0. You can now use this to filter by.
Steve
Sent: January 27, 2009 7:30 AM
Subject: Re: [Vantage] Re: Vantage - Dashboard Filters
Hi Lynn,
' (blank).
PackNums.
Cheers,
CHRIS
From: Lynn <lynn.khalife@ <mailto:lynn.khalife%40core-mfg.com> core-mfg.com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
zero number in it.
Lynn
wrote:
> Hi,
> OrderHed
> OrderDtl
> Customer
> ShipDtl
the PackNum field..
> Cheers,
> CHRIS
Hi Steve,
That's great.
Looks like it will work.
Thanks.
Chris
Sent: Tuesday, January 27, 2009 1:34:33 PM
Subject: RE: [Vantage] Re: Vantage - Dashboard Filters
Steve
From: Chris Thompson [mailto:chriselectrix@ ymail.com]
Hi Lynn,
' (blank).
PackNums.
Cheers,
CHRIS
From: Lynn <lynn.khalife@ <mailto:lynn. khalife%40core- mfg.com> core-mfg.com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
zero number in it.
Lynn
wrote:
> Hi,
> OrderHed
> OrderDtl
> Customer
> ShipDtl
the PackNum field..
> I want to only see the Orders where they don't have a PackNum..
> Cheers,
> CHRIS
Actually I think the problem here is that you need to do an outer join
between OrderDtl and ShipDtl.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Chris Thompson
Sent: Tuesday, January 27, 2009 8:30 AM
Hi Lynn,
'blank' PackNums.
Cheers,
CHRIS
<mailto:lynn.khalife%40core-mfg.com> >
zero number in it.
Lynn
wrote:
> Hi,
> OrderHed
> OrderDtl
> Customer
> ShipDtl
the PackNum field..
> Cheers,
> CHRIS
Try PackNum < 1.
Lynn
wrote:
> Hi Lynn,
> Cheers,
> CHRIS
> From: Lynn <lynn.khalife@...>
> zero number in it.
> Lynn
> wrote:
> > Hi,
> > OrderHed
> > OrderDtl
> > Customer
> > ShipDtl
> the PackNum field..
> > Cheers,
> > CHRIS
Hi Lynn,
If I import a BAQ into a Dashboard, then make an alteration to the BAQ (ie add another field) can I re-import the BAQ into the Dashboard without losing the filters etc I have in place?
Cheers,
CHRIS
Try PackNum < 1.
Lynn
wrote:
> Hi Lynn,
> Cheers,
> CHRIS
> zero number in it.
> Lynn
> wrote:
> > Hi,
> > OrderHed
> > OrderDtl
> > Customer
> > ShipDtl
> the PackNum field..
> > Cheers,
> > CHRIS
wrote:
> Hi Lynn,
> Cheers,
> CHRIS
> Try PackNum < 1.
> Lynn
> wrote:
> > Hi Lynn,
is
it
so
> > Cheers,
> > CHRIS
the
non-
> > zero number in it.
> > Lynn
> > wrote:
> > > Hi,
> > > OrderHed
> > > OrderDtl
> > > Customer
> > > ShipDtl
filter
> > the PackNum field..
> > > Cheers,
> > > CHRIS
