Vantage Error in Conversion Process
sid, I had the same error show up when I converted the end of last
year. I'm having trouble today trying to recall what I did to fix the
problem, but I'll keep looking through my notes. One thing I did do that
you haven't mentioned running, is that I did a dump and load of the 4.0
data base before I copied it and started it as a 5.0. Might be something to
try. Epicor support should have an answer, as I believe they helped me
through the problem.
At 10:56 PM 9/19/02 +0000, you wrote:
>After Running the schema changes and starting Vantage 5.0, the
>following error occured in the conversion process:
>CRC for index 'MainKey' on table 'Oprice' does not match CRC in
>procedure 'cv/cvxa0036.p'. Try recompiling (7968).
>Any ideas on what this means and how to recompile?
>Thanks....
>sid
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>have already linked your email address to a yahoo id to enable access. )
>(1) To access the Files Section of our Yahoo!Group for Report Builder and
>Crystal Reports and other 'goodies', please goto:
>http://groups.yahoo.com/group/vantage/files/.
>(2) To search through old msg's goto:
>http://groups.yahoo.com/group/vantage/messages
>(3) To view links to Vendors that provide Vantage services goto:
>http://groups.yahoo.com/group/vantage/links
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Norm Watkins
Engineering Mgr.
ELECPAC
Phone: 847-639-2307
Thanks....
sid
Sid,
Were you able to get past the error mentioned below?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, September 19, 2002 6:56 PM
Subject: [Vantage] Vantage Error in Conversion Process
Thanks....
sid
Yahoo! Groups Sponsor
ADVERTISEMENT
No I still have not found a solution. I am stumped.
sid
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> Sid,
> Troy Funte
> Liberty Electronics
> From: sidsullivan1
> To: vantage@y...
> Thanks....
> sid
> ADVERTISEMENT
access. )
Service.
Sid,
Perhaps a 'bigger picture' of the situation might help. Can you give us more information? You were converting from 4.0 to 5.0, correct? You ran the schema changes. Then you started Vantage for the first time... Did it ask you to run the Database conversions? Did you then run the conversion program in the Company Config/Utilities?
Troy Funte
Liberty Electronics
Sent: Friday, September 20, 2002 10:30 AM
Subject: [Vantage] Re: Vantage Error in Conversion Process
sid
> Sid,
> Troy Funte
> Liberty Electronics
> From: sidsullivan1
> To: vantage@y...
> Thanks....
> sid
> ADVERTISEMENT
access. )
Service.
ADVERTISEMENT
Troy,
You are correct in your outline below. I was starting vantage for
the first time when conversions ran. They ran for some time, then
ended with the noted error message.
sid
> Sid,
Config/Utilities?
> Troy Funte
> Liberty Electronics
> From: sidsullivan1
> To: vantage@y...
> sid
> > Sid,
> > Troy Funte
> > Liberty Electronics
> > From: sidsullivan1
> > To: vantage@y...
the
in
> > Thanks....
> > sid
> > ADVERTISEMENT
You
enable
> access. )
goto:
> Service.
> ADVERTISEMENT
access. )
Service.
Sid,
My guess is that something in the Schema Changes choked and you may have to run them all again from the start. That's discouraging after 10 hours (which is what it took us going from 4.0 to 5.0). There is nothing you really can compile in Progress as an end-user. The error message probably means that a file is missing that should have been there.
By the way, which patch level are you at? There was one 5.0 patch that caused a similar error that you are describing -- Epicor released a fix in the next patch.
Troy Funte
Liberty Electronics
Sent: Friday, September 20, 2002 12:24 PM
Troy,
sid
> Sid,
Config/Utilities?
> Troy Funte
> Liberty Electronics
> From: sidsullivan1
> To: vantage@y...
> sid
> > Sid,
> > Troy Funte
> > Liberty Electronics
> > From: sidsullivan1
> > To: vantage@y...
the
in
> > Thanks....
> > sid
> > ADVERTISEMENT
You
enable
> access. )
goto:
> Service.
> ADVERTISEMENT
access. )
Service.
ADVERTISEMENT
