Vantage Help died on my Terminal Server
I set up our W2K3 TS to include a domain group 'Terminal Services
Users' to be part of the local machine's Power Users Group (for
printing purposes mostly) Flash player installs OK for them and I set
Flash Security Settings Control Panel
(http://www.macromedia.com/support/documentation/en/flashplayer/help/s
ettings_manager.html) to always allow content from \\<servername
here>\epicor\mfgsys80\help
people authorized to connect to the TS are added to the domain group
and so far, knock on wood, help is working OK
Bernie.
--- In vantage@yahoogroups.com, "David Murphy" <djmurphy@...> wrote:
> A recent Microsoft Patch to Internet Explorer 6 crippled Adobe
(Macromedia) Flash add-in that is used by the Vantage help system.
> Adobe has issued an updated Flash add-in ( 9 something) that will
work if you can get it installed.
> I also have a W2K3 TS and the only way I've found to install is to
give each user admin privileges. Could live with this to install but
once you remove the privilege the Flash add-in stops working.
> I am told Adobe has a special .msi package for this situation but
I've not found it yet.
> Feel free to jump in if you know something different.
> David J. Murphy
> Information Systems Manager
> A&A Machine & Fabrication, LLC
> Elevating the Art of precision machining
> and fabrication from concept to completion
> Voice (409) 938-4274
> Fax (409) 938-3925
> www.aagroup.com
I applied some updates to my Windows 2003 Terminal Server. Vantage help
no longer works over Terminal Services. It works with direct network
connections.
Anyone have the answer ?
Cliff Drumeller
IT Manager
Mass Precision Sheetmetal, Inc.
408 786 0348
408 314 7420 Cell
A recent Microsoft Patch to Internet Explorer 6 crippled Adobe (Macromedia) Flash add-in that is used by the Vantage help system.
Adobe has issued an updated Flash add-in ( 9 something) that will work if you can get it installed.
I also have a W2K3 TS and the only way I've found to install is to give each user admin privileges. Could live with this to install but once you remove the privilege the Flash add-in stops working.
I am told Adobe has a special .msi package for this situation but I've not found it yet.
David J. Murphy
Fax (409) 938-3925
www.aagroup.com
