Vantage on Cluster
Yes, there are a few Vantage Customers who are running in a cluster.
Last I knew, there is one in Portland, OR, two in New Jersey, and one in North
Dakota who are running Vantage in a cluster.
A couple of hints/suggestions/notes for you.
1- Open Edge needs to be installed separately on the local drive in each node of
the cluster
2- Put the vantage installation on the shared drive
3- Make sure you put the shared drive with the Vantage installation as a
dependency of the OE service on each node.
4- Make sure all file paths in the vantage installation use the cluster name,
not the server names
5- You cannot do a quick switch back and forth between nodes, there will be
orphaned processes that will prevent a re-startup of vantage until they can all
be killed off, they will die naturally but they take time to die off from not
being connected.
It can be kind of a pain in the ass to be honest, while it's cool and great, I
honestly don't think most companies running Vantage really need a clustered
setup, it can honestly be a real pain in the ass and take a really really long
time to get up and running the way it should be.
Depending on why you want to use a cluster, there is likely a cheaper, and much
simpler way of accomplishing the same thing.
ramsey_burns
Sent: Friday, October 30, 2009 6:35 PM
Subject: [Vantage] Re: Vantage on Cluster
Thanks, I think that will come in handy as I'm doing this. I haven't bothered to
learn much about OpenEdge but guess now is the time.
I'll report back if I get it working.
Cheers,
-Ramsey
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Basically OpenEdge looks at the .PF file for the database and finds
> the DSN= parameter:
> -Mm 1024 -mmax 65534 -Bt 4096 -s 8000 -yy 1970 -stsh 31 -inp 32000 -tok
> 4000 -TB 31 -TM 32 -D 500 -l 1000
> -tmpbsize 8 -ttmarshal 5 -lkwtmo 180
> -T c:\epicor\mfgwrk803
> -db c:\epicor\mfgsys803\db\mfgsyssh -ld mfgsyssh -RO
> -db mfgsys803 -dt MSS -ld mfgsys
> -Dsrv
> skip_schema_check,PRGRS_CONNECT,DSN=MFGSYS803,TXN_ISOLATION,1,PRGRS_NATI
> VE_LOCKWAIT,30000
> And then uses that System DSN to connect to Vantage. You could make a
> different DSN and change the parameter there, but for simplicity's sake
> I'd suggest just changing the DSN itself and avoid head-scratching by
> yourself or your successor. :-)
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
> Of ramsey_burns
> Sent: Friday, October 30, 2009 2:23 PM
> Ah, I guess that was too obvious for me to figure out.. Thanks Brian.
> -Ramsey
> --- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@>
> wrote:
> > Well the 'pointing to a different SQL Server' task is simple: just
> change the system DSN with the same name as your OpenEdge database to
> point to the new server.
> > -bws
> / Picometrix
> > bspolarich@ ~ 734-864-5618 ~ www.advancedphotonix.com
> Behalf Of ramsey_burns
> > Sent: Friday, October 30, 2009 11:58 AM
> > Subject: [Vantage] Vantage on Cluster
> > Is anyone running on a windows cluster? Couldn't find any info if this
> is actually supported or not. A related question, how to direct an
> existing install to another SQL server? We're using .407 SQL and
> looking at a minimum to split the app server and SQL server but would be
> nice to have these be able to fail over to each other. The SQL part
> should be no problem but I have no experience with the app server
> portion.
> > Cheers,
> > -Ramsey
> > ramsey@
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Individual Email | Traditional
> http://groups.yahoo.com/group/vantage/join
> (Yahoo! ID required)
> mailto:vantage-digest@yahoogroups.com
> mailto:vantage-fullfeatured@yahoogroups.com
> vantage-unsubscribe@yahoogroups.com
> http://docs.yahoo.com/info/terms/
Is anyone running on a windows cluster? Couldn't find any info if this is actually supported or not. A related question, how to direct an existing install to another SQL server? We're using .407 SQL and looking at a minimum to split the app server and SQL server but would be nice to have these be able to fail over to each other. The SQL part should be no problem but I have no experience with the app server portion.
Cheers,
-Ramsey
ramsey@...
Well the 'pointing to a different SQL Server' task is simple: just change the system DSN with the same name as your OpenEdge database to point to the new server.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ramsey_burns
Cheers,
-Ramsey
ramsey@...
-Ramsey
> -bws
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> Cheers,
> -Ramsey
> ramsey@...
Yeah, but I have no idea about clustering. You're on your own there. ;-)
-Ramsey
> -bws
> Cheers,
> -Ramsey
> ramsey@...
the DSN= parameter:
-Dsrv
VE_LOCKWAIT,30000
-bws
Picometrix
Of ramsey_burns
-Ramsey
> -bws
/ Picometrix
portion.
> Cheers,
> -Ramsey
> ramsey@...
Thanks, I think that will come in handy as I'm doing this. I haven't bothered to learn much about OpenEdge but guess now is the time.
Cheers,
-Ramsey
> the DSN= parameter:
> -Dsrv
> VE_LOCKWAIT,30000
> -bws
> Picometrix
> Of ramsey_burns
> -Ramsey
> > -bws
> / Picometrix
> portion.
> > Cheers,
> > -Ramsey
> > ramsey@
