# Vantage Patch 4.00.811 **Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9) **Created:** 2000-08-07 09:43 UTC **Views:** 365 **Replies:** 2 **URL:** https://www.epiusers.help/t/vantage-patch-4-00-811/689 --- ## Post #1 by @system
Thanks for your suggestions (I'm not an IS person and was in a panic).
We found out that the problem was the command line in schema
change.vtg-"Connect Option" got erased or corrupt. Once we entered the
correct line everything ran fine.
Thanks again.
Gail
> -----Original Message-----
> From: William Colls [SMTP:william@...]
> Sent: Saturday, August 05, 2000 10:56 AM
> To: vantage@egroups.com; gailh@...
> Subject: Re: [Vantage] Vantage Patch 4.00.811
> It sounds as if your schema change program wants the data base in Single
> User mode. You have two choices.
> 1. Stop the db engines and then run the schema change.
> 2. Right click the change.vtg program, and look at the properties. In the
> command line, find the -1 (that's a minus one) parameter, and remove it.
> the run your schema change.
> Since schema changes can only be made when no-one else is using the DB,
> the first choice is probably your best option.
> Gail Harder wrote:
> > I have installed Vantage patch 4.00.811 and am attempting to run the
> schema
> > changes. The installation of the patch appeared install fine. I then
> > started the engines as indicated. I then went to our mapped drive
> > W:\vantage\schema change.vtg and double clicked on it. An error message
> > came up - The database W:\vantage\db\vantage is in use in multiuser
> mode.
> > What am I doing wrong?? Shouldn't I have started the engines (through
> > procontrol)? If anyone is out there please help!
> > Gail Harder
> > gailh@...
> William E. Colls Tel 613 591 0079
> PROComputer Systems Fax 613 591 3924
> 67 Willow Glen Drive www.procomsys.com
> Kanata Ontario Canada K2M 1T1 PEG 1988051404
--- ## Post #2 by @system
It sounds as if your schema change program wants the data base in Single User mode. You have two choices.
2. Right click the change.vtg program, and look at the properties. In the command line, find the -1 (that's a minus one) parameter, and remove it. the run your schema change.
Since schema changes can only be made when no-one else is using the DB, the first choice is probably your best option.
Gail Harder wrote:
> I have installed Vantage patch 4.00.811 and am attempting to run the schema
> came up - The database W:\vantage\db\vantage is in use in multiuser mode.
> Gail Harder
> gailh@...
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
Sailors, with their inbuilt sense of order and good discipline, should
really be running the world.
--- ## Post #3 by @system
Gail,
Were are you attempting to run the schema changes, from an administrative
workstation or some other workstation. I had encountered something similar
with basically the same multi user issue, and by utilizing an NT workstation
with Progress loaded on it I was able to run the utility.
Randy Vander Galien
IS Manager
Wisconsin EPS
Gail Harder
gailh@...
--- **Canonical:** https://www.epiusers.help/t/vantage-patch-4-00-811/689 **Original content:** https://www.epiusers.help/t/vantage-patch-4-00-811/689
