Vantage running, but PET states otherwise
Only 10.1B is installed on the server. A quick check for orphaned
files from 10.0 didn't turn up anything either.
HOWEVER...
Moments after my post, the server blue screened and rebooted. So I'm
guessing something was amuck deep down inside the server.
Calvin
--- In vantage@yahoogroups.com, "Todd Hofert" <todd@...> wrote:
> But do you have both versions of Progress on the server? If so, you
may
> be launching the PET for the older version.
> Todd
Behalf
> Of Calvin Krusen
> Sent: Monday, June 23, 2008 12:56 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Vantage running, but PET states otherwise
> A typo on my part. We are using OE1.01B (SP3/HF7)
> The Progress Explorer Tool was working just fine last week. Now it
> shows the db and apps as "Not Running".
> FWIY - Trying to start the MfgTest803 db yields an error. And
> becuase PET thinks its not running, the option to stop the db is
> disabled.
> I'm guessing a server reboot is inorder.
> Calvin
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "bw2868bond" <bwalker@> wrote:
> > At first glance it looks like you indicate you are using the
> OE10.0b
> > version of PET
> > Vantage 8.03.4xx runs on OE 10.1b
> > Make sure you are using correct PET
> "Calvin Krusen" <ckrusen@> wrote:
> > > Vantage running, but PET shows database and AppServers as 'Not
> > Running'.
> > > Both Vantage works ok with on both the live company db and test
> > company
> > > db.
> > > Any one run across this before?
> > > Version 8.03.403D
> > > Progress OE10.B/SP3/HotFix7/Build 1372
> > > Calvin
Vantage running, but PET shows database and AppServers as 'Not Running'.
Both Vantage works ok with on both the live company db and test company
db.
Version 8.03.403D
Calvin
At first glance it looks like you indicate you are using the OE10.0b
version of PET
Running'.
company
> db.
> Version 8.03.403D
> Calvin
disabled.
Calvin
OE10.0b
> version of PET
> Running'.
> company
> > db.
> > Version 8.03.403D
> > Calvin
But do you have both versions of Progress on the server? If so, you may
Todd
Of Calvin Krusen
disabled.
Calvin
OE10.0b
> version of PET
> Running'.
> company
> > db.
> > Version 8.03.403D
> > Calvin
