Vantage Screen Customization
Thank You Charles. The code you supplied worked great. It is much
appreciated.
Brad
--- In vantage@yahoogroups.com, "Charles Carden" <ccarden@...> wrote:
> The easiest way to accomplish this is with an after field changed
event.
> It would look similar to the following, just change the table name
to
> the appropriate table.
> Private Sub UD12_AfterFieldChange(ByVal sender As object, ByVal
args As
> DataColumnChangeEventArgs) Handles UD12_Column.ColumnChanged
> Dim edvUd12 As EpiDataView = CType(oTrans.EpiDataViews("UD12"),
> EpiDataView)
> Select Case args.Column.ColumnName
> Case "Date02"
> If edvUD12.dataview(edvUD12.Row)("Date04") is System.DBNull.Value
Then
> edvUd12.dataView(edvUd12.Row)("Date04") =
> edvUd12.dataView(edvUd12.Row)("Date02")
> End If
> Case Else
> End Select
> End Sub
Behalf
> Of brad.ebright
> Sent: Monday, June 09, 2008 3:07 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Vantage Screen Customization
> We have customized the order entry screen by adding a new tab to
the
> line level for our engineers to use. We have a couple date fields
> (Date02 and Date04) on it. The engineers are suppose to fill in the
one
> date field and we would like it to copy the information in Date02
to
> Date04, but only if Date04 is blank. Is there a way to do this.
> We have a program that then runs and send email alerts to our job
> scheduler and sales saying that the engineering dates have been
changed
> so they can make changes in the appropiate schedules.
> We are running 8.00.
> Thanks
> Charles Carden
> Manager, MIS
> Manitex, Inc.
> Phone: 512-942-3086
> Fax: 512-942-3089
> DISCLAIMER:
> This e-mail, including attachments, may include confidential and/or
> proprietary information, and may be used only by the person or
entity to
> which it is addressed. If the reader of this e-mail is not the
intended
> recipient or his or her authorized agent, the reader is hereby
notified
> that any dissemination, distribution or copying of this e-mail is
> prohibited. If you have received this e-mail in error, please
notify the
> sender by replying to this message and delete this e-mail
immediately.
We have customized the order entry screen by adding a new tab to the
(Date02 and Date04) on it. The engineers are suppose to fill in the one
date field and we would like it to copy the information in Date02 to
scheduler and sales saying that the engineering dates have been changed
The easiest way to accomplish this is with an after field changed event.
It would look similar to the following, just change the table name to
Private Sub UD12_AfterFieldChange(ByVal sender As object, ByVal args As
EpiDataView)
Case "Date02"
If edvUD12.dataview(edvUD12.Row)("Date04") is System.DBNull.Value Then
End If
Case Else
End Select
End Sub
Of brad.ebright
Charles Carden
Manager, MIS
Manitex, Inc.
Phone: 512-942-3086
Fax: 512-942-3089
DISCLAIMER:
proprietary information, and may be used only by the person or entity to
which it is addressed. If the reader of this e-mail is not the intended
recipient or his or her authorized agent, the reader is hereby notified
prohibited. If you have received this e-mail in error, please notify the
sender by replying to this message and delete this e-mail immediately.
In order to prevent app errors, don't you also need a test in there to NOT act on the guts of the code when row goes to -1 (say on a clear screen action)?
I've found that to be a sporadic (annoying) issue (depending upon the app, adapters and tables involved).
Rob Brown
--- On Mon, 6/9/08, Charles Carden <ccarden@...> wrote:
Subject: RE: [Vantage] Vantage Screen Customization
Date: Monday, June 9, 2008, 5:43 PM
Private Sub UD12_AfterFieldChan ge(ByVal sender As object, ByVal args As
DataColumnChangeEve ntArgs) Handles UD12_Column. ColumnChanged
Dim edvUd12 As EpiDataView = CType(oTrans. EpiDataViews( "UD12"),
EpiDataView)
Select Case args.Column. ColumnName
Case "Date02"
If edvUD12.dataview( edvUD12.Row) ("Date04" ) is System.DBNull. Value Then
edvUd12.dataView( edvUd12.Row) ("Date04" ) =
edvUd12.dataView( edvUd12.Row) ("Date02" )
End If
Case Else
End Select
End Sub
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of brad.ebright
To: vantage@yahoogroups .com
Charles Carden
Manager, MIS
Manitex, Inc.
Phone:
Fax:
DISCLAIMER:
