Vantage Server with dual Processors
Sounds like you need a new consultant....
Of randyduly
Sent: Wednesday, February 27, 2008 8:32 AM
Subject: Re: [Vantage][6.1] Vantage Server with dual Processors
Vantage will recognize multi-processors system, including dual-core
and quad-core and it does not affect the Vantage Licensing at all. I
am running Vantage 8.03.404 on a Dell 1900 with 2 3.0GHz Quad-core
processors. We are still in the testing stages of implementation. We
currently run our Vantage 6.1 production on a Dell 2500 dual-
processor.
Hope this helps.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Todd
Caughey <caugheyt@...> wrote:
> I believe these are also "physical CPUs" and not total of the
cores. When we put in the Dual Quadcore system we were told the 2
CPU licenses for Microsoft were for the two physical CPU chips and
not the 8 processor cores.
> -Todd C.
Behalf Of Fons van der Beek
> Sent: Tuesday, February 26, 2008 8:29 AM
> As far as I know only Simulation software can require such special
> licencing (moldflow, nastran etc etc)
> generally 2 procs are nowadays support by any software (two proc is
> rather common)
> Norm Watkins schreef:
> > For you IT pro's, I'm buying a new Dell Poweredge 1900 server for
Vantage,
> > and Dell is offering a free upgrade to a 2nd processor. An IT
consultant
> > our company uses is suggesting that a 2nd processor may require
special
> > licensing for dual processors? Is that a really a concern for
running
> > Vantage? What kind of applications would require special
licensing for dual
> > processors?
> > Norm Watkins
> > Engineering Mgr.
> > ELECPAC
> > 847-639-2307
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must have already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services goto:
> > Yahoo! Groups Links
For you IT pro's, I'm buying a new Dell Poweredge 1900 server for Vantage,
and Dell is offering a free upgrade to a 2nd processor. An IT consultant
our company uses is suggesting that a 2nd processor may require special
licensing for dual processors? Is that a really a concern for running
Vantage? What kind of applications would require special licensing for dual
processors?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
rather common)
> processors?
> Norm Watkins
> Engineering Mgr.
> ELECPAC
> 847-639-2307
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
Are you running Vantage on a Progress or SQL database? SQL can either be
licensed per user or by processor. If licensed by processor, you can
have unlimited usersconnecting, but you are required to license both
processors, not just one. Hope this helps...
Thank You,
Lauren L. Hellings
Systems Administrator
Ericson Manufacturing Co.
Of Norm Watkins
Sent: Tuesday, February 26, 2008 9:22 AM
To: Vantage@Yahoogroups. Com
Subject: [Vantage][6.1] Vantage Server with dual Processors
Vantage,
dual
processors?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
I believe these are also "physical CPUs" and not total of the cores. When we put in the Dual Quadcore system we were told the 2 CPU licenses for Microsoft were for the two physical CPU chips and not the 8 processor cores.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Fons van der Beek
rather common)
> processors?
> Norm Watkins
> Engineering Mgr.
> ELECPAC
> 847-639-2307
> Yahoo! Groups Links
Also,
You will often seen per-processor licensing on distributed solutions.
But I really do not think this is an issue for concern here.
In Vantage 8, I know in MRP processing, there is a user-adjustable field for the number of processors that can be used to run the MRP processes. I was told by development last year at Perspectives that this was to be used with multi-processor systems and that someone with multiple processors would benefit from chaning the default value from 1 to 2. I have no idea if that applies to cores or unique processors.
Carey
To: vantage@yahoogroups.comFrom: nwatkins@...: Tue, 26 Feb 2008 08:21:42 -0600Subject: [Vantage][6.1] Vantage Server with dual Processors
For you IT pro's, I'm buying a new Dell Poweredge 1900 server for Vantage,and Dell is offering a free upgrade to a 2nd processor. An IT consultantour company uses is suggesting that a 2nd processor may require speciallicensing for dual processors? Is that a really a concern for runningVantage? What kind of applications would require special licensing for dualprocessors?Norm WatkinsEngineering Mgr.ELECPAC847-639-2307
_________________________________________________________________
Helping your favorite cause is as easy as instant messaging. You IM, we give.
http://im.live.com/Messenger/IM/Home/?source=text_hotmail_join
No concern, Vantage will run just fine. I would question the 1900
though. You don't get as much flexibility for redundancy - look into a
PowerEdge 2900. Keep in mind you will be running your company on this
application so don't skimp on the hardware.
Just my nickels worth.
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
312.533.4033 x8039
jason@...
Of Norm Watkins
Vantage,
dual
processors?
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
processor.
Hope this helps.
> -Todd C.
> rather common)
Vantage,
consultant
special
running
licensing for dual
> > processors?
> > Norm Watkins
> > Engineering Mgr.
> > ELECPAC
> > 847-639-2307
access. )
> > Yahoo! Groups Links
