We currently use the product configuration to optimise sheet material
based on quantities of cuts outs required
We use code to read the part master and return the best optimised
material into the BOM.
The problem is, this only optimises sheets on a line by line basis (ie
one panel size at a time)
Does anyone process sheet material optimization on a whole quote (ie
many different panel sizes, all quote lines)
If so could anyone suggest which sheet optimisation software works best
with vantage
Thanks in Advance
Gary
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
with vantage
Thanks in Advance
Gary
