Vantage Styling & Themes and Citrix
Hi Jeff
The LOCAL color quality setting properties must be set higher than 16 Bit on the work stations you deploy the Theme on
Don
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jplehr
Sent: Tuesday, August 17, 2010 9:11 AM
Subject: [Vantage] Vantage Styling & Themes and Citrix
Vantage 8.03.408A
Looking for anyone using Vantage in a Citrix environment.
I just started working with Styling & Themes. Currently testing out ideas for our Multi Company environment. By following along in the Tools User Guide and some Answer Book documents I have been able to change colors of the Favorites List and the Main Menu and I have been able to make them different for each company. I also added the respective company logo to the main desktop area within Vantage. I have been able to add the different logos and when changing companies I am seeing everything I expected to see.
Here is the catch... I do all of my work from a specific Citrix Server Desktop, where everything looks correct. When I say correct this includes launching things like Job Entry, Sales Order Entry, etc. But, when I launch Vantage from the Citrix Published Application I am able to see the logos and respective changes for each company, as previously mentioned, but the problem comes when I launch things like Job Entry, Sales Order Entry, etc. The typical gray areas are now black. I can still see all of the respective buttons, sheets and fields but everything else is black.
You Citrix users have any thoughts? Your help would be greatly appreciated.
Jeff
Vantage 8.03.408A
Jeff
