Vantage Ver6.1 - forms to PDF
PDF Redirect.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-9873 x110 a Fax 401-596-1050
www.maxsonautomatic.com
_____
Dunn, Nancy
Sent: Monday, June 14, 2010 3:29 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Vantage Ver6.1 - forms to PDF
In the past I have used PrimoPDF to convert Vantage forms to PDF files.
Now the process isn't working for some users, or it will work sometimes and
not other times.
Can anyone recommend an easy and cheap way to get a Vantage form to PDF
format?
Anyone else having the same problem with PrimoPDF?
Thanks for your help.
Nancy
Hi all,
We are currently in the midst of a upgrade from 8.03.408 to epicor 9.
Epicor is doing the upgrade on our sites via webex.
One thing that I don't understand (I never had any training, just learned by myself) is the schema.
What is it? What does it do? What's the purpose of it? Etc. If anyone would be kind to explain it to me or give me any documentation to educate myself on it I would really appreciate it.
Ephraim Feldman
Ephraim Feldman
Schema is simply a definition of what tables exists, and which fields within those tables exists.
When you have a schema change, it represents addition or deletion of tables/fields within Epicor. Often times this means having to move data from the old field to the new.
It also can be changes to relationships between tables.
You can use the Data Dictionary Viewer & Dataset Relationships under System Management to bring some visibility to the schema.
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of effgroups@...
Sent: Monday, June 14, 2010 10:55 AM
Subject: [Vantage] Schema - Bayesian Filter detected spam
Hi all,
Ephraim Feldman
Ephraim Feldman
Simply put, the schema is your database layout. It includes Tables, field names, all their properties, validation, relationships, etc.. Basically everything about your database except the data itself.
Sent: Mon, June 14, 2010 12:54:52 PM
Â
Hi all,
Ephraim Feldman
Ephraim Feldman
Ephraim,
Schema is basically the database definition. Some fields might be renamed
requiring mapping, others might change their length for example. That is how
I understand it.
Randy Weber
Vantage Consultant
(651) 998-9322
weber.randy@...
http://randallweber.com
On Mon, Jun 14, 2010 at 11:54 AM, <effgroups@...> wrote:
> Hi all,
> Ephraim Feldman
> Ephraim Feldman
Randy Weber
weber.randy@...
(651) 263-1811
http://randallweber.com/
The schema is your database layout. This shows all of the tables and
their fields along with the relationships between the tables. Knowing
how all of the tables relate to each other makes it much easier to
create reports or even custom applications. It is really great to have
a visual representation of the schema when you are learning to write
reports from any database. You can use a program like Erwin to produce
a giant poster of the database schema and post on a wall. I find this
to be of great value.
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of effgroups@...
Sent: Monday, June 14, 2010 12:55 PM
Hi all,
Ephraim Feldman
Ephraim Feldman
I see
So the program collects the information of my database.
Now what's the schema change that is run when upgrading ?
Ephraim
Ephraim Feldman
Date: Mon, 14 Jun 2010 10:01:19
To: <vantage@yahoogroups.com>
Subject: Re: [Vantage] Schema
Â
Hi all,
Ephraim Feldman
Ephraim Feldman
But why does a schema change have to be run before upgrading to 9 ? What can be changed that epicor doesn't know?
Ephraim Feldman
Date: Mon, 14 Jun 2010 10:59:33
To: vantage@yahoogroups.com<vantage@yahoogroups.com>
Subject: RE: [Vantage] Schema - Bayesian Filter detected spam
Ken
Hi all,
Ephraim Feldman
Ephraim Feldman
Now the process isn't working for some users, or it will work sometimes and not other times.
Can anyone recommend an easy and cheap way to get a Vantage form to PDF format?
Nancy
A schema change may be the addition or deletion of a table or field or relationship. Any database change is a change to the schema.
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Sent: Monday, June 14, 2010 3:12 PM
I see
Ephraim
Ephraim Feldman
From: Steven Gotschall <sgotschall@... <mailto:sgotschall%40yahoo.com> >
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
From: "effgroups@... <mailto:effgroups%40gmail.com> " <effgroups@... <mailto:effgroups%40gmail.com> >
Hi all,
Ephraim Feldman
Ephraim Feldman
The database is being modified to work with the version 9 software (this
is a schema change). If an installation is made that calls on a
database table or field that has not been setup, then the installation
will fail.
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of effgroups@...
Sent: Monday, June 14, 2010 3:14 PM
Subject: Re: [Vantage] Schema - Bayesian Filter detected spam
Ephraim Feldman
<mailto:kwilliams%40intermountainelectronics.com> >
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <
Ken
Behalf Of effgroups@... <mailto:effgroups%40gmail.com>
Hi all,
Ephraim Feldman
Ephraim Feldman
If you log into Vantage and search for epicor9-v803400schemachanges you will find a document that lists all the changes.
Hth,
Linda
I see
Ephraim
Ephraim Feldman
Hi all,
Ephraim Feldman
Ephraim Feldman
We use CutePDF - it's free and always works. It installs easily and shows up
as a printer.
Randy Weber
weber.randy@...
(651) 263-1811
Thank you Randy, I will give it a try.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Randall Weber
Sent: Monday, June 14, 2010 8:10 PM
as a printer.
Randy Weber
weber.randy@...<mailto:weber.randy%40gmail.com>
(651) 263-1811
