As long as you know how to write the ODBC connection to the db and your
other language can use ODBC you could technically use any language to talk
to the DB. You could easily write an ASP.NET website to pull data from the
DB and display it on a website. You could even use it to manipulate the
website. If you wanted to take on the risk of wrecking the DB.
~Charlie.
PS we use PHP to generate a small website that is constantly displayed on a
Terminal on the Foreman stand that display some info about which employees
are and are not logged into jobs.
I didn't write the PHP for this it has been here since before I started
working here. I don't really have any PHP experience.
_____
Mark Wonsil
Sent: Friday, August 08, 2008 10:12 AM
Subject: RE: [Vantage] VB And Progress
Could you write you extract as a WebService? Is your other program capable
of making http requests?
BTW, I would not worry too much about the performance of ODBC. In fact, if
you wanted to, you could write a Java/JDBC program that accesses the
Progress database and that could certainly be launched by a batch file.
Mark W.
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.6.0/1601 - Release Date: 8/8/2008
9:02 AM
~Charlie.
_____
Mark Wonsil
> I wasn't planning to use the VBS from with in vantage I was planning toCharlie,
> it just to extract data from the database for a secondary piece of
> software we are planning on using.
Mark W.
9:02 AM
