VB Code Not Entering Loop
I don't know if you solved this problem yet or not but I usually structure my loops as follows:
Dim LineRow As CustShipDataSet.ShipDtlRow
For Each LineRow In adShip.CustShipData.ShipDtl
If LineRow.PackLine = pckLine Then
lotnum = LineRow.LotNum
End If
Next
Now my question for you. I have not been able to figure out the proper structure for GetList in version 9. I see that you use it in the snippet... did that work?
--- In vantage@yahoogroups.com, "jeffery_p_sanders" <jps@...> wrote:
> Thanks for the information. I added your code and it returns :
> "Tables(SubShipH) is something"
> and
> "Rows count = 0"
> I do not understand this as there are rows in the database for that vendor number.
> At least I now know where to start looking...Thanks!
> Jeff Sanders
> --- In vantage@yahoogroups.com, "rhecksabre" <rheck@> wrote:
> > Not sure, but you may try adding this to make sure you have something to loop over:
> > 'to make sure you get an object and get into loop
> > if isNothing(ShipADP.SubConShipEntryData.Tables("SubShipH")) then
> > MessageBox.Show("Tables(SubShipH) is nothing")
> > else
> > MessageBox.Show("Tables(SubShipH) is something")
> > 'to make sure there are rows
> > MessageBox.Show("Rows count = " & ShipADP.SubConShipEntryData.Tables("SubShipH").Rows.Count)
> > end if
> > > for each row as DataRow in ShipADP.SubConShipEntryData.Tables("SubShipH").Rows
> > > venNum = row("VendorNum")
> > > messagebox.show("VenNum=" & cstr(venNum))
> > > next row
> > --- In vantage@yahoogroups.com, "jeffery_p_sanders" <jps@> wrote:
> > > Can anyone tell me what I am doing wrong in the for each loop shown below?
> > > Private Sub epiUltraComboC1_RowSelected(ByVal sender As Object, ByVal args As Infragistics.Win.UltraWinGrid.RowSelectedEventArgs)
> > > ' ** Place Event Handling Code Here **
> > > System.Windows.Forms.Cursor.Current = System.Windows.Forms.Cursors.WaitCursor
> > > epiNumericEditorC1.ResetValue()
> > > epiTextBoxC1.Clear()
> > > epiUltraGridC1.ResetBindings()
> > > dim vID as string
> > > dim vNum as integer
> > > dim vNam as string
> > > vID = epiUltraComboC1.value
> > > Dim vendorADP As VendorAdapter = New VendorAdapter(UD05Form)
> > > vendorADP.BOConnect()
> > > Dim gotVendor As Boolean = vendorADP.GetByID(vID)
> > > Dim vTable As DataTable = VendorADP.VendorData.Vendor.DataSet.Tables.Item(0)
> > > vNum = vTable.rows(0)("VendorNum")
> > > vNam = vTable.rows(0)("Name")
> > > epiTextBoxC1.text = vNam
> > > epiNumericEditorC1.value = vNum
> > > vendorADP.Dispose()
> > > Dim ShipADP as SubConShipEntryAdapter = New SubConShipEntryAdapter(UD05Form)
> > > ShipADP.BOConnect()
> > > Dim opts As SearchOptions = New SearchOptions(SearchMode.AutoSearch)
> > > opts.NamedSearch.WhereClauses.Add("VendorNum",vNum)
> > > Dim MorePages as boolean
> > > Dim ShipDS As Data.DataSet = ShipADP.GetList(opts, MorePages)
> > > EpiUltraGridC1.dataSource = ShipDS
> > > dim venNum as int32
> > > next row
> > > ShipADP.Dispose()
> > > System.Windows.Forms.Cursor.Current = System.Windows.Forms.Cursors.Arrow
> > > End Sub
> > > Thanks,
> > > Jeff Sanders
dim vID as string
dim vNum as integer
dim vNam as string
vendorADP.Dispose()
ShipADP.BOConnect()
dim venNum as int32
next row
ShipADP.Dispose()
End Sub
Jeff Sanders
else
end if
> next row
> dim vID as string
> dim vNum as integer
> dim vNam as string
> vendorADP.Dispose()
> ShipADP.BOConnect()
> dim venNum as int32
> next row
> ShipADP.Dispose()
> End Sub
> Thanks,
> Jeff Sanders
and
"Rows count = 0"
Jeff Sanders
> else
> end if
> > next row
> > dim vID as string
> > dim vNum as integer
> > dim vNam as string
> > vendorADP.Dispose()
> > ShipADP.BOConnect()
> > dim venNum as int32
> > next row
> > ShipADP.Dispose()
> > End Sub
> > Thanks,
> > Jeff Sanders
