Vb customization - data not saving to ud table unless
I believe that's correct...the string I had in there was this...
edvUD11.Notify( New EpiNotifyArgs(oTrans, edvUD11.Row,edvUD11.Column) )
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
(Click the logo to view our site)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, December 20, 2011 3:36 PM
Subject: Re: [Vantage] vb customization - data not saving to ud table unless..
Yeha you need to notify, is Notify not working for you?
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Tue, Dec 20, 2011 at 4:09 PM, Rob Bucek <rbucek@...> wrote:
> Ok..
> Step 1 user types empnum into text box bound to shortchar07 tabs out,
> event fires a list lookup, their name populates a text box bound to
> shortchar08..works great. Click save, nothing happens. Refresh and
> data reverts back to previous values.
> If they do step one AND enter data into a text box bound to
> shortchar05 say, and then click save, the data sticks.
> Sent from my Verizon Wireless 4G LTE Phone
> -----Original message-----
> From: Jose Gomez <jose@...>
> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> Sent: Tue, Dec 20, 2011 20:51:31 GMT+00:00
> unless..
> I am not sure I understand, where does the record stick?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Tue, Dec 20, 2011 at 3:48 PM, Rob Bucek <rbucek@...> wrote:
> > Jose,
> > Thanks for quick reply, had that in there before, yanked it because
> > it wasn't effective. Started digging in the archives.. found an old
> > post by bwBond on what seemed to be a similar issue..took a while to
> > find
> it..you
> > know how searching those is.
> > I had to put the row in an edit mode..
> > EdvUD11.dataview(edvUd11.Row)beginedit() etc....
> > Which I know works great but drives me nuts because im still trying
> > to learn the fundumentals of this stuff lol... the record sticks
> > without
> that
> > code if I manually enter data into another field before saving the
> entire
> > record..
> > I have it working, but am still curious if you might have some
> > insight into what is causing that behavior..
> > Rob Bucek
> > FAX: (715)284-4084
> Behalf
> > Of Jose Gomez
> > Sent: Tuesday, December 20, 2011 2:38 PM
> > table unless..
> > try
> > edvYourVIew.Notify(new
> > EpiNotifyArgs(oTrans,edvYourView.Row,edvYourView.Column))
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Tue, Dec 20, 2011 at 3:33 PM, Rob Bucek <rbucek@...> wrote:
> > > So I have a ud table that users are entering data into. A
> > > shortchar field where they type their employee number into, when
> > > they tab it does a list look up, validates, and populates that
> > > field with the number, and another with their name. Unless I
> > > manually enter data into another native control, say a date/time
> > > editor or another text box tied to a shortchar field before I
> > > attempt to save, it won't save the data populated from the list
> > > lookup (char 7 & 8), though in either instance you do see the
> > > information fill into the controls.. do I need to do some type of
> > > notification to the row in order to cement the
> > changes (before saving)?
> > > Private Sub txtEmpNum_LostFocus(ByVal Sender As Object, ByVal Args
> > > As
> > > System.EventArgs) Handles txtEmpNum.LostFocus '// ** Place Event
> > > Handling Code Here ** Dim txtEmp As EpitextBox =
> > > ctype(csm.GetNativeControlReference("cbdc76bb-a22a-4476-a294-80829
> > > e6df
> > > c16"),EpitextBox) Dim whereClause As String = "EmpID = '" +
> > > txtEmp.Text + "'"
> > > Dim recSelected As Boolean
> > > Dim dsEmpSearch As DataSet
> > > If (txtEmp.Text <> String.Empty) Then dsEmpSearch =
> > > Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
> > > "EmpBasicAdapter", recSelected, False, whereClause) If
> > > (recSelected =
> > > False) Then MessageBox.Show("Employee does not exist")
> > > txtEmp.Clear()
> > > txtEmp.Focus()
> > > Else
> > > Dim edvUD11 As EpiDataView = CType(oTrans.EpiDataViews("UD11"),
> > > EpiDataView)
> > > edvUD11.dataView(edvUD11.Row)("ShortChar08") =
> > > dsEmpSearch.Tables(0).Rows(0)("EmpID")
> > > edvUD11.dataView(edvUD11.Row)("ShortChar07") =
> > > dsEmpSearch.Tables(0).Rows(0)("Name")
> > > End If
> > > End If
> > > End Sub
> > > Rob Bucek
> > > FAX: (715)284-40
So I have a ud table that users are entering data into. A shortchar field where they type their employee number into, when they tab it does a list look up, validates, and populates that field with the number, and another with their name. Unless I manually enter data into another native control, say a date/time editor or another text box tied to a shortchar field before I attempt to save, it won't save the data populated from the list lookup (char 7 & 8), though in either instance you do see the information fill into the controls.. do I need to do some type of notification to the row in order to cement the changes (before saving)?
Private Sub txtEmpNum_LostFocus(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles txtEmpNum.LostFocus
'// ** Place Event Handling Code Here **
Dim txtEmp As EpitextBox = ctype(csm.GetNativeControlReference("cbdc76bb-a22a-4476-a294-80829e6dfc16"),EpitextBox)
Dim whereClause As String = "EmpID = '" + txtEmp.Text + "'"
dsEmpSearch = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "EmpBasicAdapter", recSelected, False, whereClause)
If (recSelected = False) Then
txtEmp.Clear()
txtEmp.Focus()
Else
Dim edvUD11 As EpiDataView = CType(oTrans.EpiDataViews("UD11"), EpiDataView)
edvUD11.dataView(edvUD11.Row)("ShortChar08") = dsEmpSearch.Tables(0).Rows(0)("EmpID")
edvUD11.dataView(edvUD11.Row)("ShortChar07") = dsEmpSearch.Tables(0).Rows(0)("Name")
End If
End If
End Sub
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
try
*Jose C Gomez*
*Software Engineer*
E: jose@...
> dsEmpSearch =
> txtEmp.Clear()
> txtEmp.Focus()
> Else
> EpiDataView)
> End If
> End If
> End Sub
> Rob Bucek
> FAX: (715)284-4084
Jose,
Thanks for quick reply, had that in there before, yanked it because it wasn't effective. Started digging in the archives.. found an old post by bwBond on what seemed to be a similar issue..took a while to find it..you know how searching those is.
Which I know works great but drives me nuts because im still trying to learn the fundumentals of this stuff lol... the record sticks without that code if I manually enter data into another field before saving the entire record..
I have it working, but am still curious if you might have some insight into what is causing that behavior..
Rob Bucek
FAX: (715)284-4084
try
*Jose C Gomez*
*Software Engineer*
E: jose@...
> txtEmp.Text + "'"
> dsEmpSearch =
> "EmpBasicAdapter", recSelected, False, whereClause) If (recSelected =
> txtEmp.Clear()
> txtEmp.Focus()
> Else
> EpiDataView)
> End If
> End If
> End Sub
> Rob Bucek
> FAX: (715)284-4084
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose,
> record..
> Rob Bucek
> FAX: (715)284-4084
> Of Jose Gomez
> unless..
> try
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > txtEmp.Text + "'"
> > dsEmpSearch =
> > txtEmp.Clear()
> > txtEmp.Focus()
> > Else
> > EpiDataView)
> > End If
> > End If
> > End Sub
> > Rob Bucek
> > FAX: (715)284-4084
Ok..
Step 1 user types empnum into text box bound to shortchar07 tabs out, event fires a list lookup, their name populates a text box bound to shortchar08..works great. Click save, nothing happens. Refresh and data reverts back to previous values.
If they do step one AND enter data into a text box bound to shortchar05 say, and then click save, the data sticks.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose,
> record..
> Rob Bucek
> FAX: (715)284-4084
> Of Jose Gomez
> unless..
> try
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > txtEmp.Text + "'"
> > dsEmpSearch =
> > txtEmp.Clear()
> > txtEmp.Focus()
> > Else
> > EpiDataView)
> > End If
> > End If
> > End Sub
> > Rob Bucek
> > FAX: (715)284-40
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Ok..
> unless..
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Jose,
> it..you
> that
> entire
> > record..
> > Rob Bucek
> > FAX: (715)284-4084
> Behalf
> > Of Jose Gomez
> > unless..
> > try
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > txtEmp.Text + "'"
> > > dsEmpSearch =
> > > txtEmp.Clear()
> > > txtEmp.Focus()
> > > Else
> > > EpiDataView)
> > > End If
> > > End If
> > > End Sub
> > > Rob Bucek
> > > FAX: (715)284-40
