VB form help
Thank you Calvin,
Off list Calvin offered the following:
Aaron -
Something I remember having to do in the past.
Change the name of the file and put it in the ud folder
RUNPROG ud/udJobLog.p
Log out of Vantage and log back in on the client and
let me know if that fixed it.
Calvin
Sure enough, now something happens. Now just to get the code to do what I
want.
Thank you.
Aaron
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Aaron Hoyt
Sent: Friday, October 14, 2005 8:36 AM
Subject: RE: [Vantage] VB form help.
Calvin,
Good thought, I had not tried it that way, but sadly same results.
Aaron
Of Calvin Dekker
Sent: Friday, October 14, 2005 8:24 AM
Aaron -
Just an idea try a forward slash:
RUNPROG vbp/joblog.p
Log out of Vantage, restart the client session and try the
button.
I just checked one of my routines, syntax is as follows:
RUNPROG ud/udAIAGLabel.p
HTH,
Calvin
-------Original Message-------
Date: 10/13/05 11:11:10
My command looks like this.
RUNPROG v:\mfgsys61\vbp\JobLog.p
I can't get it to find the file wherever I put it. Just File
v:\mfgsys61\vbp\JobLog.p not found.
Grrr.
Any ideas?
Aaron
>mailto:vantage@yahoogroups.com">vantage@yahoogroups.com
Of Brandon Murch
Sent: Thursday, October 13, 2005 11:46 AM
I have a button that calls a .p program and this is the command I am
using:
RUNPROG z:\vantage\vbp\order.p
I know that I had to put the .p file in the VBP directory in order for
Vantage to see it...
Brandon R Murch
Supervisor of Information Technology
WindStone Medical Packaging
406.259.6387
bmurch@... <mailto:bmurch@...>
Sent: Thursday, October 13, 2005 9:39 AM
Thanks you Brandon,
Sounds great, but all I get when trying to call a .p lately is file not
found.
Any thought on that?
I have a .p that should work using DOS command, but can't get Vantage to
find it in VBP even calling out the full path.
Grrrr.
Aaron
Of Brandon Murch
Sent: Thursday, October 13, 2005 11:28 AM
Aaron,
Would a .p file assigned to the button work?
I did some searching on www.progresstalk.com
<http://www.progresstalk.com/> and found some sample code which may
help in getting excel to open:
DEF VAR ExcelApp AS COM-HANDLE NO-UNDO.
DEF VAR ExcelWkbk AS COM-HANDLE NO-UNDO.
DEF VAR ExcelFileName AS CHARACTER NO-UNDO.
ASSIGN ExcelFileName = "filename.
CREATE "Excel.Application":U ExcelApp NO-ERROR.
/*Open Excel*/
chExcelApplication:VISIBLE = TRUE.
/*open workbook*/
ExcelWkbk = ExcelApp:workbooks:OPEN(ExcelFileName).
I think if you used the vb.i program as well to call the jobnum
associated with operation you may be able to parse that into the
ExcelFileName variable.
Brandon R Murch
406.259.6387
Sent: Thursday, October 13, 2005 8:56 AM
To: Vantage Group
Subject: [Vantage] VB form help.
Requesting help again for an issue I was helped with once before I
think.
I have a VB form that I am trying to use a button on.
It's the JobOperation VBForm. I would like to be able to use the
current
job number in a call to an outside program. What I am trying to do it
call
an excel file by the same name as the job number. Can anyone help me?
I could create a BAM to do this and just sacrifice one of the VB
checkboxes,
but I would rather have a button so it looks nice.
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
Privileged and/or confidential information may be contained in
this message. If you are not the addressee indicated in this
message (or are not responsible for deliver of this message to
that person), you may not copy or deliver this message to
anyone. In such case, you should destroy this message and
notify the sender by reply e-mail. If you or your employer do
not consent to Internet e-mail for messages of this kind,
please advise the sender. Windstone Medical Packaging,
Inc. does not provide or endorse any opinions, conclusions
or other information in this message that do not relate to the
official business of the company.
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
Crystal Reports and other 'goodies', please goto: http://groups.yahoo
(2) To search through old msg's goto: http://groups.yahoo
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Requesting help again for an issue I was helped with once before I think.
It's the JobOperation VBForm. I would like to be able to use the current
job number in a call to an outside program. What I am trying to do it call
I could create a BAM to do this and just sacrifice one of the VB checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
Are you calling any other programs from inside JobLog.p?
Brandon R Murch
406.259.6387
Sent: Thursday, October 13, 2005 10:01 AM
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
I guess "calling" was the wrong word, I meant any includes...
Brandon R Murch
406.259.6387
Sent: Thursday, October 13, 2005 10:08 AM
Brandon R Murch
406.259.6387
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Not sure if this is the same type of thing you are trying to do but once upon a time I created a button to fire off acrobat reader with our quality documents (an ISO thing for shop floor to be able to read them).
In the VB Form the button command was: RUNVBP QAPROC.VBP
then QAPROC.VBP (edited with notepad) was located in the VBP folder. It seemed to find it OK without the full pathing.
The VBP routine was:
shellexec v:\sharePDF\qaproc.pdf
MSGBOX Press OK to continue
Maybe the RUNPROG there instead for the shellexec instead of doing it directly on the button command?
I know it took me a long time with VB to get this "two-step" to work.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Aaron Hoyt
Sent: Thursday, October 13, 2005 11:01 AM
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
< http://www.progresstalk.com/> and found some sample code which may
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
< http://groups.yahoo.com/group/vantage/files/>
SPONSORED LINKS
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu> &k=Manufacturing+software&w1=Manufactu
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man> &k=Membership+database+software&w1=Man
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf> &k=Database+mortgage+software&w1=Manuf
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur> &k=Pda+database+software&w1=Manufactur
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man> &k=Database+management+software&w1=Man
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu> &k=Database+marketing+software&w1=Manu
_____
YAHOO! GROUPS LINKS
< http://groups.yahoo.com/group/vantage> " on the web.
Service < http://docs.yahoo.com/info/terms/> .
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software Database <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
Have you tried RUNPROG JobLog.p? It seem like when I first played with
BAM's I had similar issues and it was because I was specifying the path.
Just a thought.
Butch
Of Aaron Hoyt
Sent: Thursday, October 13, 2005 9:01 AM
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
I think Todd might be onto something.
I have tried about every variant...
.p, .r, with vbp\, with full path, with nothing...can't seem to find a file
with runprog directly from the VB form for me.
I am going to try to dance a little two step with it to see if I can loosen
things up a bit. :)
I will let everyone know my progress.
Aaron
Of Butch Menge
Sent: Thursday, October 13, 2005 12:58 PM
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Groups Links
All right.
Can anyone that is running V6.1 526 or above and Progress 9.1D 0920 check to
see if RUNPROG can find a file?
No matter what I do and how I do it, this can't find a file. Even creating
a VBP (I can find those) can't find the .p with a RUNPROG command.
This is getting beyond frustrating at this point.
Aaron
Of Aaron Hoyt
Sent: Thursday, October 13, 2005 2:25 PM
things up a bit. :)
Aaron
Of Butch Menge
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Groups Links
Yahoo! Groups Links
Remember to sign out of Vantage. If you copy the file to vbp and try to
execute it in Vantage without getting out of Vantage first, it doesn't think
it's there. It caches that directory when you sign in.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, October 13, 2005 12:13 PM
> All right.
> to
> creating
> Thanks,
> Aaron
> Of Aaron Hoyt
> loosen
> things up a bit. :)
> Thanks,
> Aaron
> Of Butch Menge
> Just a thought.
> Butch
> Of Aaron Hoyt
> Grrr.
> Any ideas?
> Aaron
> Of Brandon Murch
> using:
> Brandon R Murch
> 406.259.6387
> From: Aaron Hoyt [mailto:aaron.hoyt@...]
> Thanks you Brandon,
> found.
> Grrrr.
> Aaron
> Of Brandon Murch
> Aaron,
> /*Open Excel*/
> /*open workbook*/
> Brandon R Murch
> 406.259.6387
> To: Vantage Group
> think.
> current
> call
> checkboxes,
> Any ideas?
> Thanks,
> Aaron Hoyt
> Vantage Plastics
> SPONSORED LINKS
> _____
> YAHOO! GROUPS LINKS
> _____
> have
> and
> Yahoo! Groups Links
> _____
> YAHOO! GROUPS LINKS
> _____
> have
> and
> Yahoo! Groups Links
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
> have
> Yahoo! Groups Links
> have
> Yahoo! Groups Links
> Yahoo! Groups Links
Have you tried:
RUNPROG vbp\JobLog.p
Of Aaron Hoyt
Sent: Thursday, October 13, 2005 2:13 PM
All right.
Aaron
Of Aaron Hoyt
things up a bit. :)
Aaron
Of Butch Menge
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
I just got of the phone with Support. If I rename the .p to VBsample.p it
does not say it can't find the file. They are both in the same directory,
but it can find a file by their test name, but not mine. Something is a bit
fishy here.
Anyone with ideas?
Aaron
Of Aaron Hoyt
Sent: Thursday, October 13, 2005 3:13 PM
All right.
Aaron
Of Aaron Hoyt
things up a bit. :)
Aaron
Of Butch Menge
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Ok, that seems to be supported by the name thing, but...I tried exiting
Vantage, clearing working directory and restarting, though if I don't use
VBsample.p it can't find the file. I allowed it to refresh, but still my
file does not exist to Vantage. I am about to start testing my coed using
the filename VBsample.p to see if it will run that code. Meanwhile I
welcome any thoughts.
Aaron
Of Chris Robisch
Sent: Thursday, October 13, 2005 3:30 PM
Subject: Re: [Vantage] VB form help.
> All right.
> to
> creating
> Thanks,
> Aaron
> Of Aaron Hoyt
> loosen
> things up a bit. :)
> Thanks,
> Aaron
> Of Butch Menge
> Just a thought.
> Butch
> Of Aaron Hoyt
> Grrr.
> Any ideas?
> Aaron
> Of Brandon Murch
> using:
> Brandon R Murch
> 406.259.6387
> Thanks you Brandon,
> found.
> Grrrr.
> Aaron
> Of Brandon Murch
> Aaron,
> /*Open Excel*/
> /*open workbook*/
> Brandon R Murch
> 406.259.6387
> To: Vantage Group
> think.
> current
> call
> checkboxes,
> Any ideas?
> Thanks,
> Aaron Hoyt
> Vantage Plastics
> SPONSORED LINKS
> _____
> YAHOO! GROUPS LINKS
> _____
> have
> and
> Yahoo! Groups Links
> _____
> YAHOO! GROUPS LINKS
> _____
> have
> and
> Yahoo! Groups Links
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
> have
> Yahoo! Groups Links
> have
> Yahoo! Groups Links
> Yahoo! Groups Links
Yahoo! Groups Links
yup, I know I used to be able to do this...
Now nothing.
I am starting to get suspicious of either a progress or vantage patch.
Aaron
Of Podlin, Michael
Have you tried:
Of Aaron Hoyt
All right.
Aaron
Of Aaron Hoyt
things up a bit. :)
Aaron
Of Butch Menge
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Just out of sheer curiosity, what if you enclose the path and filename
with quotes? No idea what it might solve, but like I said, sheer
curiosity...
Brandon R Murch
406.259.6387
Sent: Thursday, October 13, 2005 1:31 PM
it
directory,
bit
fishy here.
Anyone with ideas?
Aaron
Of Aaron Hoyt
All right.
check to
creating
Aaron
Of Aaron Hoyt
file
loosen
things up a bit. :)
Aaron
Of Butch Menge
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Tried that with several variants. Just can't find that either.
Interestingly enough...if I use the Vbsample.p file name, the code won't
execute, it's like if you use their filename it ignores the request
altogether, and if you use any other, it can't find the file. Support's
answer was the file was missing the vb.i include file. Although the error
is exactly the same, it makes no difference to include the vb.i or not.
Again I say...Grrr.
Aaron
Of Brandon Murch
Sent: Thursday, October 13, 2005 3:34 PM
curiosity...
Brandon R Murch
406.259.6387
it
directory,
bit
fishy here.
Anyone with ideas?
Aaron
Of Aaron Hoyt
All right.
check to
creating
Aaron
Of Aaron Hoyt
file
loosen
things up a bit. :)
Aaron
Of Butch Menge
Just a thought.
Butch
Of Aaron Hoyt
Grrr.
Any ideas?
Aaron
Of Brandon Murch
using:
Brandon R Murch
406.259.6387
Thanks you Brandon,
found.
Grrrr.
Aaron
Of Brandon Murch
Aaron,
/*Open Excel*/
/*open workbook*/
Brandon R Murch
406.259.6387
To: Vantage Group
think.
current
call
checkboxes,
Any ideas?
Aaron Hoyt
Vantage Plastics
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
have
and
Yahoo! Groups Links
SPONSORED LINKS
YAHOO! GROUPS LINKS
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
Here's how one of ours works... this is fundamental stuff.
On the Shop Employee's VBForm OK Button, we have:
runprog eiempbasicok.p
That program has {vb.i} as the first line (braces, not parentheses).
Ensure you're storing the program in the VBP directory of the Vantage you're
in.
Sent: Thursday, October 13, 2005 12:29 PM
> Have you tried:
> Of Aaron Hoyt
> All right.
> to
> creating
> Thanks,
> Aaron
> Of Aaron Hoyt
> loosen
> things up a bit. :)
> Thanks,
> Aaron
> Of Butch Menge
> Just a thought.
> Butch
> Of Aaron Hoyt
> Grrr.
> Any ideas?
> Aaron
> Of Brandon Murch
> using:
> Brandon R Murch
> 406.259.6387
> Thanks you Brandon,
> found.
> Grrrr.
> Aaron
> Of Brandon Murch
> Aaron,
> /*Open Excel*/
> /*open workbook*/
> Brandon R Murch
> 406.259.6387
> To: Vantage Group
> think.
> current
> call
> checkboxes,
> Any ideas?
> Thanks,
> Aaron Hoyt
> Vantage Plastics
> SPONSORED LINKS
> _____
> YAHOO! GROUPS LINKS
> _____
> have
> and
> Yahoo! Groups Links
> _____
> YAHOO! GROUPS LINKS
> _____
> have
> and
> Yahoo! Groups Links
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
> have
> Yahoo! Groups Links
> have
> Yahoo! Groups Links
> Yahoo! Groups Links
> Yahoo! Groups Links
