Thanks for the help, Sean!
Â
Keith Walter
Vantage Coordinator
Norgren Automation Solutions, Saline Division
keith.walter@...
Sent: Tue, March 23, 2010 12:41:25 PM
Subject: RE: [Vantage] Re: VB Help - update a system field
Â
Instead of key1=…
Do this:
[edvVarName] .dataView( [edvVarName] .Row)("PartNum" ) = <value>
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Keith
Sent: Tuesday, March 23, 2010 11:50 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Re: VB Help - update a system field
OK, found it. Once I get this object, how do I write to it? It seems to be showing me how to retrive a value into a variable, I want to write to the object itself, right?
Keith
Â
Keith Walter
Vantage Coordinator
keith.walter@...
Â
Instead of key1=…
Do this:
Keith
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> , "Sean McDaniel" <smcdanie@.. .> wrote:
> Typically, when I change a field value I change it at the database level.
> If you are in customization, go to object explorer, click on middle tab, expand to table field you want to get/set data from and it will have an example like this…
> Dim Key1 as string
> Dim [edvVarName] As EpiDataView = CType(oTrans. EpiDataViews( "ReportParam" ), EpiDataView)
> Key1 = [edvVarName] .dataView( [edvVarName] .Row)("PartNum" )
> From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> [mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On Behalf Of Keith Walter
> Sent: Tuesday, March 23, 2010 11:23 AM
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Subject: Re: [Vantage] VB Help - update a system field
> Thanks Sean, that seems to update the value, but it is not consistant. When I enter a number in the LaborHrs field, the BurdonHrs change accordingly, but when I tab out of the field, the value reverts back to what it was. Is there another event I could use? Can I force an update to make the value stick? Here is my code:
> Private Sub txtLbrHrsCust_ ValueChanged( ByVal Sender As Object, ByVal Args As System.EventArgs) Handles txtLbrHrsCust. ValueChanged
> '// ** Place Event Handling Code Here **
> dim myVariable as EpiNumericEditor
> myVariable=CType( csm.GetNativeCon trolReference( "2fb3632e- e429-4503- 86cf-6b353409116 a"),EpiNumericEd itor)
> myVariable.Value = txtLbrHrsCust. Value
> End Sub
> Thanks,
> Keith Walter
> Vantage Coordinator
> keith.walter@ ... <mailto:keith. walter%40norgren auto.com>
> ____________ _________ _________ __
> From: Sean McDaniel <smcdanie@.. . <mailto:smcdanie% 40rochester. rr.com> >
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> <mailto:vantage% 40yahoogroups. com>
> Sent: Tue, March 23, 2010 10:47:40 AM
> Subject: RE: [Vantage] VB Help - update a system field
> You need to do something like this to get to that textbox.
> myVariable
> =CType(csm.GetNativ eControlReferenc e("bdda2b2b- d8b4-4c89- a9e1-77466d34d7f c
> "),EpiNumericEditor )
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of
> Keith Walter
> Sent: Tuesday, March 23, 2010 9:53 AM
> Subject: [Vantage] VB Help - update a system field
> I am trying to update the Labor Entry form to auto-update the Burden Hrs
> field when you enter Labor hrs. I could not add an event to the system
> Labor Hrs field, so I added a custom textbox and added this code:
> Dim txtbox as object = nbrBurdenHrs
> txtbox.Value = txtLbrHrsCust. Value
> End Sub
> But my compile fails: Name 'nbrBurdenHrs' is not declared.
> How do I declare this to update the value? Is there a better way to do
> this?
> Thanks,
> Keith Walter
> Vantage Coordinator
> keith.walter@ norgrenauto. com <mailto:keith. walter%40norgren auto.com>
