VendNum was not found in Buffer ttSupplierPartList
Thanks for your help Stephen - We deleted the receipt and re-entered it and it worked!
Adrian
On 10 Jan 2014, at 14:19, Stephen Edginton <stephene@...> wrote:
<div id="ygrps-yiv-705086189ygrp-text">
  <p>
Sounds like base try removing the supplier part references
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Adrian Lauchlan
Sent: 09 January 2014 18:19
Subject: RE: [Vantage] VendNum was not found in Buffer ttSupplierPartList
Hi Stephen
We are on 9.05.604.
It hangs when we click receive all
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stephen Edginton
Sent: 09 January 2014 01:55
Adrian,
Looks like a base bug induced by the supplier part cross reference data, you could try removing the association of a cross reference.
What version of Epicor is this for?
At what point does it hang on saving the receipt?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of adrian.lauchlan
Sent: 08 January 2014 19:33
Subject: [Vantage] VendNum was not found in Buffer ttSupplierPartList
Hi
We are trying to receive items against a PO but the receipt just hangs and we have to stop Epicor and restart it. I have checked the logs and the following msg is being reported:
VendNum was not found in buffer ttSupplierPartList (7351)
Unable to evaluate arguments for Temp-Table Method
Any suggestions?
</div>
Hi
Any suggestions?
Adrian,
Hi
Any suggestions?
Hi Stephen
We are on 9.05.604.
Adrian,
Hi
Any suggestions?
Hi Stephen
We are on 9.05.604.
Adrian,
Hi
Any suggestions?
