Ver 9.05 Change suggestions
Currently when purchasing is going through there change suggestion they group by Brw-Exception.  The only problem is when they delete a suggestion the system will jump to the next PO number that maybe somewhere else in the list.  Is there a way to modify the tree view or sort so when the item is deleted it will jump to the next item based on the sort?
Steve
