Marty,
This morning works fine.
Kathleen
_____
Of Marty
Sent: Thursday, February 26, 2009 8:38 AM
Subject: [Vantage] Re: Verifying Labor and Burden in the Last Cost
Field.
Kathleen
I would very much appreciate the help in this area. Let me know
when a good time to call you on this subject. Doesn't have to be
today if you are busy..
Marty
"Kathleen Tyrrell" <ktyrrell@...>
wrote:
Behalf
contain confidential and privileged information. If you are not an
intended recipient, please contact the sender by reply e-mail and
destroy all copies of this message, including attachments. Any
unauthorized review, use, disclosure or distribution is prohibited.
Kathleen
_____
Of Marty
Field.
Kathleen
Marty
wrote:
>stock?
> Marty,
> I have information that could help, but might be better to talk via
> phone
> than email. Let me know if you are interested in the approach.
> Questions that I would have:
> what costing method is set on the part?
> was there on hand inventory prior to the receipt of the job to
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> what is the labor rate assigned to the shop employee?
> what is the burden rate assigned to the resource?
> Kathleen Tyrrell
> TJI & Affiliates
> Inventory Control
> 360-453-3445
> _____
Behalf
> Of MartyField.
> Sent: Thursday, February 26, 2009 8:07 AM
> Subject: [Vantage] Verifying Labor and Burden in the Last Cost
>inventory.
> I called Epicor Technical Help this morning asking them to explain
> to me how this transaction works. I was told it takes the actual
> cost of the part at the time the parts are received into
> And this information comes from the Production Detail Report ofthe
> job it's produced on.Report
> My problem is trying to verify these #'s. I have the print out of
> the Production Detail Report the morning before the finished parts
> were received into inventory and I have been using that report to
> try to tie into the Unit Labor and Unit Burden Last Costs and I am
> $0.35 higher in Labor and $0.80 higher in burden then what the
> system calculated. I even tried to use the Production Detail
> from the following morning and had no luck.this
> When I talked to the Epicor help person he told me to look at the
> Part Transaction History Tracker for the detail of the transaction
> and that should give me the answers I am looking for. I went to
> report and I see the #'s but still don't know how they wereany
> calculated. Plus I have a cost in Labor Unit Cost field and Mtl
> Labor Unit Cost (same for burden) but I have no idea where the Mtl
> Labor/Burden Unit Cost came from since I am not aware we charge
> labor/burden to the material.to
> I am just trying to understand how this works so I can explain it
> others.attachments, is for the sole use of the intended recipients and may
> Thanks.
> NOTICE OF CONFIDENTIALITY: This e-mail message, including
>NOTICE OF CONFIDENTIALITY: This e-mail message, including attachments, is for the sole use of the intended recipients and may contain confidential and privileged information. If you are not an intended recipient, please contact the sender by reply e-mail and destroy all copies of this message, including attachments. Any unauthorized review, use, disclosure or distribution is prohibited.
