Hello Mark,
Technically there is no default ODBC User ID and Password for Vista 4.3. If you are running a Visual FoxPro DB backend then there is no user/password restriction. If you are running on an SQL Server database instance then the login credentials for the ODBC DSN is the "sa" user with whatever password was set for that user. Typically, it is blank.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
On Dec 26, 2011, at 3:31 AM, Mark wrote:
> Hello All,
> Does someone know the default User ID and Password for the ODBC connection for Vista 4.3?
> Thank you in advance
