So sorry George that I didn't read your question until this morning. At that point the DUU instructions to 9.05.700 stated that the backup run after the 9.04 conversions should be restored. I have no idea where that other file comes from. I searched my test server and couldn't find anything like that from the DUU to 9.05.700 conversion. I hope you found your answer and were able to finish over the weekend. If you found the answer to your question and have a few minutes I'd appreciate it if you could post that answer as I may be testing the new DUU utility to 9.05.701 in a few weeks. Thanks!
Sue
Sue
--- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@...> wrote:
> Hello Sue;
> Ran into a problem with the 9.05.701 DUU section 5.2 "Run Manual Conversion 10080 - Progress Only".
> It says I need to copy the file "mfgsysshmt" from the \Upgrade904\Backup folder, but that doesn't exist in there. Any ideas?
> It appears that you need to restore the 9.04 Schema Holder into a folder then it can use the data from the 9.04 DB to update the transaction links in the 9.05 DB.
> Did you run across this? Hot topic if you or anyone else can help tonight or early tomorrow morning.
> George
> --- In vantage@yahoogroups.com, "snielsen28" <snielsen.hipco@> wrote:
> > The SCR for the missing converted GLTtran payroll records is 106566. Good luck with your conversions!
> > Sue
> > --- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@> wrote:
> > > Thanks Sue!
> > > Yes, I spoke to support today and confirm that the .410 will work with the DUU.
> > > That is a good note on the PR Table, as there are a few folks including my last company, that use the Payroll module. I imagine it is not a big deal if you don't use the PR module.
> > > I am going to go from 8.03.407C to .410 then use the DUU to go to 9.05.700C. I have experience with .700 bugs and .700C was stable enough for us. The feedback I read here on the .701 left me to decide not to go there yet, until they get some patches for the bugs in .701
> > > Can you pass along the SCR# for the PR Bug?
> > > I will be doing the conversions to live this week, so wish me luck and thanks for the support from the group, as always.
> > > Regards,
> > > George Hicks
> > > > We are on Vantage 8.03.409A but the same may apply for Vista. I was told with the DUU to 9.05.700 that it would work from 8.03.410 even though the documentation says 409C. I was also led to believe that upgrading from 410 may be better because some "prep work" for Epicor 9 conversions had been done in the 410 version of Vantage. I used the DUU from Vantage 8.03.410 to Epicor 9.05.700. The only problem I've found so far is that the payroll/GL links weren't brought over to the GLCTrans table. I was given an SCR for that and told it was targeted for 703. On my next practice conversion, I plan on going from 8.03.409A to 8.03.410 and then use the DUU from 8.03.410 to 9.05.701. Hope this helps.
> > > > Sue
> > > > > Good Evening all;
> > > > > The DUU specifies that is written to use Vist 8.03.409C as it's starting point. That release is not downloadable anymore since they came out with 8.03.410. Does anyone know if we go to 8.03.410, will the DUU work or kack out because we are not on .409C?
> > > > > Wouldn't ya think that if the DUU required .409C they would leave that one up just for that reason? Hmmmmmm....
> > > > > Any guidance appreciated.
> > > > > Regards,
> > > > > George Hicks
