Visual Basic Question
Thanks allot Jeff, you have probably saved my holiday weekend.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Thursday, August 29, 2002 11:11 AM
Subject: RE: [Vantage] Visual Basic Question
Jeremy,
Here are some pieces of our VB.NET code that shows one way to do it.
////////// Dim a few things you will need //////////
Dim cn As New ADODB.Connection()
Structure rsClone 'Structure contains all the details of Forecast,Job
and Order details
Public EDIKey As String
Public PartNum As String
Public Gen_Date As Date
Public Actual_Qty As Long
Public Del_Date As Date
Public Qty As Long
Public DueDate As Date
Public CreatedDate As Date
Public Date05 As Date
Public NeedByDate As Date
End Structure
Dim rsClone1() As rsClone
Dim oJobDetails() As JobDetails
Dim oOrderDetails() As OrderDetails
Const ConnectString As String =
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source="
Dim rs As New ADODB.Recordset(), rs1 As New ADODB.Recordset(), rs2 As
ADODB.Recordset, rs3 As ADODB.Recordset
////////// Set the connection on form load (you will have multiple
connections) /////////////
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles MyBase.Load
Dim MyQry As String, i As Short
With cn
.ConnectionString = ConnectString &
"T:\DATA\ACCESS\?????\MyDatabase.mdb;Persist Security Info=False"
.Open()
End With
'Populate the records with some PartNum so that we have some sorta
dispplay when the app is executed
PopulateRecords("10090908-101")
LoadgrdGenDate() 'Load the Gen Date grid
LoadgrdDetails() 'Load appropriate Values into Details grid
and so on...
/////// Populate the recordsets using the queries -- then populate
structures from the recordsets ///////
Private Sub PopulateRecords(ByVal PartNum As String)
Dim MyQry As String, MyQry1 As String, i As Short, MQ As Long,
MyQry2 As String
Dim Gdate As Date
MyQry = "SELECT Distinct EDIDtl.EDIKey,EDIHead.Gen_Date,
EDIDtl.PartNum, EDIDtl.Revision, EDIDtl.Actual_Qty, EDIDtl.Del_Date " &
_
"FROM JitPartNum INNER JOIN (EDIDtl INNER JOIN EDIHead ON
EDIDtl.EDIKey = EDIHead.EDIKey) " & _
"ON JitPartNum.PartNum = EDIDtl.PartNum " & _
"WHERE(((EDIDtl.PartNum) = '" & PartNum & "')) " & _
"ORDER BY EDIHead.Gen_Date,EDIDtl.EDIKey, EDIDtl.Del_Date;"
rs.Open(MyQry, cn, ADODB.CursorTypeEnum.adOpenStatic,
ADODB.LockTypeEnum.adLockReadOnly)
If rs.RecordCount Then
MyQry1 = "SELECT JitOrders.ReqQty, JitOrders.Date05,
JitOrders.NeedByDate, JitOrders.PartNum " & _
"FROM JitOrders " & _
"WHERE (((JitOrders.NeedByDate)>#1/11/2001#) AND
((JitOrders.PartNum)='" & _
PartNum & "')) AND JitOrders.Date05> #" &
rs.Fields("Gen_Date").Value & "#;"
rs1 = New ADODB.Recordset()
rs1.Open(MyQry1, cn, ADODB.CursorTypeEnum.adOpenStatic,
'If rs1.RecordCount Then MsgBox("order present")
MyQry2 = "SELECT CreatedDate,DueDate,ProdQty + StockQty as
TotalQty FROM JitJobs WHERE PartNum='" & PartNum & _
"' AND CreatedDate> #" &
CDate(rs.Fields("Gen_Date").Value) & "# ORDER BY CreatedDate;"
rs2 = New ADODB.Recordset()
rs2.Open(MyQry2, cn, ADODB.CursorTypeEnum.adOpenStatic,
'If rs2.RecordCount Then MsgBox("job present")
CDate(rs.Fields("Gen_Date").Value) & "# ORDER BY DueDate;"
rs3 = New ADODB.Recordset()
rs3.Open(MyQry2, cn, ADODB.CursorTypeEnum.adOpenStatic,
'Initialise the StDate and EndDate
rs.MoveFirst()
StDate = rs.Fields("Gen_Date").Value
rs.MoveLast()
EndDate = rs.Fields("Del_Date").Value
rs.MoveFirst()
ReDim rsClone1(rs.RecordCount)
'populate values from the EDIDtl table
MaxQty = 0
While Not rs.EOF
With rsClone1(i)
.EDIKey = rs.Fields("EDIKey").Value
.PartNum = rs.Fields("PartNum").Value
.Actual_Qty = rs.Fields("Actual_Qty").Value
.Del_Date = rs.Fields("Del_Date").Value
.Gen_Date = rs.Fields("Gen_Date").Value
End With
If rs.Fields("Actual_Qty").Value > MaxQty Then MaxQty =
If rs.Fields("Gen_Date").Value < StDate Then StDate =
If rs.Fields("Del_Date").Value > EndDate Then EndDate =
rs.MoveNext() : i += 1
End While
and so on...
//// write the values from the populated structure to the grid /////
'Loads the values into the Gen Date Grid from the rsclone1 object
Private Sub LoadgrdGenDate()
Dim i As Short, GDate As Date, j As Short = 1, EDIKey As String
With Me.grdGenDate
While i < rsClone1.GetUpperBound(0)
GDate = rsClone1(i).Gen_Date : EDIKey = rsClone1(i).EDIKey
If GDate = CDate("12:00:00 AM") Then Exit While
.Rows.Count += 1
.Item(j, 1) = rsClone1(i).Gen_Date
.Item(j, 2) = rsClone1(i).EDIKey
j += 1 : i += 1
While rsClone1(i).Gen_Date = GDate And EDIKey =
rsClone1(i).EDIKey
i += 1
If i >= rsClone1.GetUpperBound(0) Then Exit While
End While
End While
.AutoSizeCol(1)
.AutoSizeCol(2)
.Row = 1
End With
End Sub
A structure was used in this program because they are easy to work with
and the info is also needed to display graphically in a picture box.
Jeff
Sent: Thursday, August 29, 2002 5:49 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Visual Basic Question
I have a Visual Basic question I am hoping someone here can help
me with.
I have a standard data grid activeX control on my form. I need
to do a join
on two tables from two different data sources. In this case,
its MSSQL
Server and our Progress Vantage Database. Currently I
populating the data
grid by linking it to an ADODatacontrol activeX object. I
change the
select statement on the ADODatacontrol to change my recordset.
The problem
is, the ADO ActiveX control only allows a connection to one Data
source at a
time. I also run into the same problem if I try to use the Data
Environment
Tools in Visual Basic.
I'm sure that its a common task to do a join on two tables from
two
different data source in Visual Basic and I'm just not seeing
the obvious.
Any help would be greatly appreciated.
Jeremy Leonard
IT Manager
K-T Corporation
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.2225242/D=egroupweb/S=1705
007183:HM/A=1182689/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-1039
-335>
Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You must have already linked your email address to a yahoo id to enable
access. )
(1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
I have a Visual Basic question I am hoping someone here can help me with.
I have a standard data grid activeX control on my form. I need to do a join
on two tables from two different data sources. In this case, its MSSQL
Server and our Progress Vantage Database. Currently I populating the data
grid by linking it to an ADODatacontrol activeX object. I change the
select statement on the ADODatacontrol to change my recordset. The problem
is, the ADO ActiveX control only allows a connection to one Data source at a
time. I also run into the same problem if I try to use the Data Environment
I'm sure that its a common task to do a join on two tables from two
different data source in Visual Basic and I'm just not seeing the obvious.
Jeremy Leonard
IT Manager
K-T Corporation
Jeremy,
and Order details
Public Qty As Long
End Structure
With cn
.Open()
End With
and so on...
MyQry2 As String
Dim Gdate As Date
_
rs.MoveFirst()
rs.MoveLast()
rs.MoveFirst()
MaxQty = 0
While Not rs.EOF
With rsClone1(i)
End With
End While
and so on...
With Me.grdGenDate
.Rows.Count += 1
j += 1 : i += 1
rsClone1(i).EDIKey
i += 1
End While
End While
.AutoSizeCol(1)
.AutoSizeCol(2)
.Row = 1
End With
End Sub
Jeff
me with.
to do a join
its MSSQL
populating the data
change the
The problem
source at a
Environment
two
the obvious.
Jeremy Leonard
IT Manager
K-T Corporation
ADVERTISEMENT
-335>
access. )
