Visual Scheduling board lock
Thanks for the feedback guys, I thought there must of been a fix like the
FIXCLOCK51.r for DC lock ups. I will forward this to my local epicor support
person. I think they have problems sourcing the fix from there knowledge
base when there is a number of similar topic's to search through.
Mark Howard
Financial Controller
This email, together with any attachments, is intended for the named
recipient(s) only and may contain privileged and confidential information.
No information within this email can be forwarded via email or verbally
without the consent of the sender.
If not an intended recipient of this email, you must not copy, distribute or
rely upon it and any form of disclosure, modification, distribution and/or
publication of this email is prohibited.
Unless stated otherwise, this email represents only the views of the sender
and not the views of Jaws Buckets & Attachments.
Sent: Friday, September 27, 2002 11:27 PM
Subject: RE: [Vantage] Visual Scheduling board lock..
This has been an interesting thread on licensing. We are having the same
problems here. I just thought it was our system. I wonder why Epicor isn't
informing me of these known problems. If it wasn't for this group I don't
know what I would do.
Paul L.
ASPI
Sent: Friday, September 27, 2002 7:33 AM
Bart, Dan,
You are absolutely right. The party line is, boot everyone out (might as
well reboot the server while you are at it). When I addressed this directly
with Tim L (Epicor) he filled me in that it could be run without removing
anyone. When I addressed this the next time with support, I was given the
same party line. I suggested the alternative and they said the directions
are what they are to prevent liability in the event a session should get
screwed up by the reset. The second time I talked to support I got a
separate program that works better on DC licenses. I was having a problem
with the first reset program not resetting DC users. The second one (that I
only run when a DC user can't get a license that should be there) displays a
count of valid licenses vs. "reset license procedure complete".
In short, YES you can run this with all users still in.
Aaron Hoyt
Design Standards
Sent: Friday, September 27, 2002 8:19 AM
To: 'vantage@yahoogroups.com'
I talked to tech support about getting everyone out of Vantage before
running resetlic and they told me that I could run it with everyone still
in.
Bart Sgroi
Sent: Friday, September 27, 2002 8:06 AM
Aaron,
I am forced to run the resetlic.r about every month or two, because it
doesn't release licenses. I have to shut down form Vantage 15 data
collection stations and all of the desk tops before I run this program.
Are you telling me I do not have to boot everyone out of Vantage?
First of all I am shocked that the directions may be flawed, but this would
be great if I didn't have to burn off the mornings doughnuts by walking to
each work station.
Thanks for the tip, I may try it.
Dan
Sent: Friday, September 27, 2002 7:28 AM
There is a quicker and less painful answer to this. Support has a couple of
programs that will kill the old sessions (not showing in promon) called
something like resetlic.r or something like that. I have had a big issue
with this lately, so I now have a computer that runs a modified vantage.vtg
file (set to run the .r) three times a day. This has been working
wonderfully and, unlike the directions I was sent with it, I don't boot
everyone out of Vantage before running it.
This might save a few headaches. Be sure and mention that it is DC users
that you are trying to reset.
It's been a life saver for me.
Aaron Hoyt
Design Standards
Sent: Friday, September 27, 2002 6:58 AM
Mark,
I have the same sort of problem with the data collection licenses when one
of my data collection stations crashes. I have 3 licenses and it will tell
me I am over my limit when I only have 2 functioning at that time. The
system still thinks there is a session going where there is not. Support
has informed me (and it works for my data collection machines) that you have
to shut down and restart the database to clear the error. You have to get
everyone off the system so it is inconvenient, but you might give it a
try....hope this helps.
Diane Rowberry
Westwood Precision, Inc.
Sent: Thursday, September 26, 2002 3:37 PM
Subject: [Vantage] Visual Scheduling board lock..
I have one of my schedulers crash out of Vantage and now when he goes into
Vantage to the board. It says the board is in use, how can I tell who is
locking up the board??... The scheduler only has one sesion open and I see
nothing wrong in Promon. The access to the board in only set for 2 poeple
and the other person is on hoildays.
Vantage version 5.1
Mark Howard
or
sender
Sent: Tuesday, September 17, 2002 9:19 PM
Subject: Re: [Vantage] (OT)Crystal Date Display
Thanks Dan and Dennis! Both solutions worked!!
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
Burton, Michigan
----- Original Message -----
Sent: Monday, September 16, 2002 4:05 PM
Hi Wendy,
I found that you have to create a formula and display this field where
you
want the date range querried to appear. Try the following:
//{@DisplayDateRange}
ToText(Minimum({YourParameterFieldName})) +"To" +
ToText(Maximum({YourParameterFieldName}))
Crystal has a technical support website that addresses displaying
parameter fields in reports. the article no is c2002512. The address is
http://support.crystaldecisions.com/library/kbase/articles/c2002512.asp
hope this helps
dennis
Sent: Monday, September 16, 2002 2:16 PM
Subject: [Vantage] (OT)Crystal Date Display
Hey everyone!
Okay, call me a "derr" but I forgot how to display my Crystal
parameter
on my report. I have a report where the user chooses a date range and I
would like that date range parameter that they have chosen to display on
the
report. Does anyone have a refresher for me?
Thanks!
Wendy Bowen
Burton, Michigan
have
Yahoo! Groups Sponsor
ADVERTISEMENT
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system ( http://www.grisoft.com).
Version: 6.0.391 / Virus Database: 222 - Release Date: 9/19/2002
Outgoing mail is certified Virus Free.
ADVERTISEMENT
<http://rd.yahoo.com/M=229441.2397090.3822005.2225242/D=egroupweb/S=17050071
83:HM/A=1189560/R=0/*http://www.bmgmusic.com/acq/ee/q6/enroll/mhn/10/>
Vantage version 5.1
Mark Howard
Wendy Bowen
Burton, Michigan
Hi Wendy,
I found that you have to create a formula and display this field where you
hope this helps
dennis
Hey everyone!
Okay, call me a "derr" but I forgot how to display my Crystal parameter
would like that date range parameter that they have chosen to display on the
Thanks!
Wendy Bowen
Burton, Michigan
Mark,
Diane Rowberry
Vantage version 5.1
Mark Howard
or
sender
Wendy Bowen
Burton, Michigan
Hi Wendy,
you
hope this helps
dennis
Hey everyone!
parameter
the
Thanks!
Wendy Bowen
Burton, Michigan
have
ADVERTISEMENT
Aaron Hoyt
Design Standards
Mark,
Diane Rowberry
Vantage version 5.1
Mark Howard
or
sender
Wendy Bowen
Burton, Michigan
Hi Wendy,
you
hope this helps
dennis
Hey everyone!
parameter
the
Thanks!
Wendy Bowen
Burton, Michigan
have
ADVERTISEMENT
Aaron,
each work station.
Dan
Aaron Hoyt
Design Standards
Mark,
Diane Rowberry
Vantage version 5.1
Mark Howard
or
sender
Wendy Bowen
Burton, Michigan
Hi Wendy,
you
hope this helps
dennis
Hey everyone!
parameter
the
Thanks!
Wendy Bowen
Burton, Michigan
have
ADVERTISEMENT
Checked by AVG anti-virus system (http://www.grisoft.com).
in.
Bart Sgroi
Aaron,
each work station.
Dan
Aaron Hoyt
Design Standards
Mark,
Diane Rowberry
Vantage version 5.1
Mark Howard
or
sender
Wendy Bowen
Burton, Michigan
Hi Wendy,
you
hope this helps
dennis
Hey everyone!
parameter
the
Thanks!
Wendy Bowen
Burton, Michigan
have
ADVERTISEMENT
Bart, Dan,
Aaron Hoyt
Design Standards
in.
Bart Sgroi
Aaron,
each work station.
Dan
Aaron Hoyt
Design Standards
Mark,
Diane Rowberry
Vantage version 5.1
Mark Howard
or
sender
Wendy Bowen
Burton, Michigan
Hi Wendy,
you
hope this helps
dennis
Hey everyone!
parameter
the
Thanks!
Wendy Bowen
Burton, Michigan
have
ADVERTISEMENT
Aaron,
Sounds like you need to get VNC and install it on your data collection
workstations. That way you can log them off Vantage or reboot them from
your workstation -- and save your calories for other tasks... unless you
like doing your morning walk through the company.
Troy Funte
Liberty Electronics
To: <vantage@yahoogroups.com>
Sent: Friday, September 27, 2002 8:05 AM
> Aaron,
would
> each work station.
> Dan
> From: Aaron Hoyt [mailto:aaron@...]
of
vantage.vtg
> Aaron Hoyt
> Design Standards
> From: Diane Rowberry [mailto:diane.rowberry@...]
> Mark,
tell
have
> Diane Rowberry
> From: Mark Howard [mailto:mhoward@...]
into
see
poeple
> Vantage version 5.1
> Mark Howard
information.
distribute
> or
and/or
> sender
> From: Wendy Bowen [mailto:wpursche@...]
> Wendy Bowen
> Burton, Michigan
> From: Dennis Houghton
> Hi Wendy,
> you
> hope this helps
> dennis
> From: Wendy Bowen
> Hey everyone!
> parameter
> the
> Thanks!
> Wendy Bowen
> Burton, Michigan
> have
and
> ADVERTISEMENT
and
have
have
Troy,
Been there, done that.
The reset is only needed if a computer crashes or for some unknown reason
(read shop employee plays with it) it get's shut off while it still has a
session open.
For normal reboots and such I use VNC all the time. I have tweaked the DC
terminals so that they auto-logon to the network and start Vantage and go
directly to DC screen. In fact, from Vantage, I have eliminated the DC icon
from their menu so they can't get 4 DC screens going at once. Any problems,
I just close vantage and logoff that computer using VNC. About 45 seconds
to 1 minute later, it is back up and ready to go.
I appreciate the info though, it was not to long ago that I was running
around to each computer, and this was very valuable advice at that time, and
will be to anyone who is just watching the list and not asking questions.
Aaron Hoyt
Design Standards
Sent: Friday, September 27, 2002 9:05 AM
Subject: Re: [Vantage] Visual Scheduling board lock..
Aaron,
Troy Funte
Liberty Electronics
> Aaron,
would
> each work station.
> Dan
of
vantage.vtg
> Aaron Hoyt
> Design Standards
> Mark,
tell
have
> Diane Rowberry
into
see
poeple
> Vantage version 5.1
> Mark Howard
information.
distribute
> or
and/or
> sender
> Wendy Bowen
> Burton, Michigan
> Hi Wendy,
> you
> hope this helps
> dennis
> From: Wendy Bowen
> Hey everyone!
> parameter
> the
> Thanks!
> Wendy Bowen
> Burton, Michigan
> have
and
> ADVERTISEMENT
and
have
have
Sounds like you got it covered. Way to Go.
Troy
Sent: Friday, September 27, 2002 9:35 AM
> Troy,
> session open.
icon
problems,
and
> Thanks,
> Aaron Hoyt
> Design Standards
> From: Troy Funte [mailto:tfunte@...]
> Aaron,
> Troy Funte
> Liberty Electronics
> From: <dans@...>
> > Aaron,
> would
to
> > each work station.
> > Dan
couple
> of
issue
> vantage.vtg
users
> > Aaron Hoyt
> > Design Standards
> > Mark,
one
> tell
Support
> have
get
> > Diane Rowberry
> into
is
> see
> poeple
> > Vantage version 5.1
> > Mark Howard
> information.
verbally
> distribute
> > or
> and/or
> > sender
> > Wendy Bowen
> > Burton, Michigan
> > Hi Wendy,
where
> > you
is
> > hope this helps
> > dennis
> > From: Wendy Bowen
> > Hey everyone!
> > parameter
I
on
> > the
> > Thanks!
> > Wendy Bowen
> > Burton, Michigan
> > have
> and
> > ADVERTISEMENT
> and
> have
and
> have
and
and
have
problems here. I just thought it was our system. I wonder why Epicor isn�t
informing me of these known problems. If it wasn�t for this group I don�t
Paul L.
ASPI
Bart, Dan,
Aaron Hoyt
Design Standards
in.
Bart Sgroi
Aaron,
each work station.
Dan
Aaron Hoyt
Design Standards
Mark,
Diane Rowberry
Vantage version 5.1
Mark Howard
or
sender
Wendy Bowen
Burton, Michigan
Hi Wendy,
you
hope this helps
dennis
Hey everyone!
parameter
the
Thanks!
Wendy Bowen
Burton, Michigan
have
ADVERTISEMENT
ADVERTISEMENT
