Visual Scheduling Board
It would depend somewhat on how you setup and use vantage but you could
compare the job operations with the quote operations using report builder or
crystal reports and leave the part master file and schedule board for
scheduling.
Your second question is answer by looking at the Schedule Factors you can
use in Vantage. (SS Start to Start, FS Finish to Start, FF Finish to Finish)
By setting the second and third operation to SS (Start to Start) they will
overlap the way you want.
Patrick Winter
Sent: Tuesday, January 11, 2005 12:30 PM
Subject: [Vantage] Re: Visual Scheduling Board
Our problem is we evaluate our actual productivity against our quoted
productivity. The quoted cycle times are loaded into the jobs, not actual
rates which tends to make it tough to use Vantage to schedule. The reason
we use our quoted rates is because we have a gain share program established
which is affected by overall productivity. If we put actual rates in
Vantage, this standard would be blown out of the water. On a different note
First op : 100 hours
second op : 10 hours
third op : 120 hours
How do you overlap these operations, so that the schedule would read
correctly of all 3 operations? These three operations could be running at
the same time, but as you can see, because the secondary operation is 10% of
the other two, the secondary operation, technically would take from the time
you started, until the last piece is finished off the first operation.
Thus, overall labor might be 10 actual hours, but could span over several
weeks.
--- In vantage@yahoogroups.com, pjw@s... wrote:
> Yes, we use the visual schedule board. We update the part master
record with
> actual run efficiencies (or at least with numbers production
control would
> prefer to see for scheduling purposes) of parts using report
builder reports
> comparing the work centers rates for a part with the actual labor
and
> quantities reported. Basically linking the PartOpr table to the
labordtl
> table then comparing setup, hours, pieces, pounds, whatever. We
are a high
> volume repetitive type shop so we are looking for fixing the
routings that
> are on the extreme edges such as it runs much faster than routed or
runs
> much slower than routed. Sorting by the variance lets you work on
the worst
> offenders.
> Patrick Winter
> From: Don Green [mailto:deg@m...]
> Sent: Tuesday, January 11, 2005 7:32 AM
> Subject: Re: [Vantage] Visual Scheduling Board
> have you got any responses back from anyone. I am also interested
in this
> kwest_bmc wrote:
> > Does any one use the Visual Scheduling Board to schedule
production
> > through out a multi-operational shop? If so, how do you
incorporate
> > actual part efficiencies into the schedule? Are there any other
> > scheduling packages being used with Vantage?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
> > have already linked your email address to a yahoo id to enable
access.
> > (1) To access the Files Section of our Yahoo!Group for Report
Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > *Yahoo! Groups Links*
> > * To visit your group on the web, go to:
> > * To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > <mailto:vantage-unsubscribe@yahoogroups.com?
subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/>.
> >No virus found in this incoming message.
> >Checked by AVG Anti-Virus.
> >Version: 7.0.300 / Virus Database: 265.6.9 - Release Date: 1/6/2005
> No virus found in this outgoing message.
> Version: 7.0.300 / Virus Database: 265.6.10 - Release Date:
1/10/2005
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
Does any one use the Visual Scheduling Board to schedule production
through out a multi-operational shop? If so, how do you incorporate
have you got any responses back from anyone. I am also interested in this
> have already linked your email address to a yahoo id to enable access. )
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
Version: 7.0.300 / Virus Database: 265.6.10 - Release Date: 1/10/2005
Yes, we use the visual schedule board. We update the part master record with
actual run efficiencies (or at least with numbers production control would
prefer to see for scheduling purposes) of parts using report builder reports
comparing the work centers rates for a part with the actual labor and
quantities reported. Basically linking the PartOpr table to the labordtl
table then comparing setup, hours, pieces, pounds, whatever. We are a high
volume repetitive type shop so we are looking for fixing the routings that
are on the extreme edges such as it runs much faster than routed or runs
much slower than routed. Sorting by the variance lets you work on the worst
offenders.
Patrick Winter
Yahoo! Groups Links
No response as of yet.
in this
production
incorporate
must
access. )
Builder
1/10/2005
in this
production
incorporate
must
access. )
Builder
1/10/2005
actual rates which tends to make it tough to use Vantage to
schedule. The reason we use our quoted rates is because we have a
gain share program established which is affected by overall
productivity. If we put actual rates in Vantage, this standard would
be blown out of the water. On a different note :
running at the same time, but as you can see, because the secondary
operation is 10% of the other two, the secondary operation,
technically would take from the time you started, until the last
piece is finished off the first operation. Thus, overall labor might
be 10 actual hours, but could span over several weeks.
record with
control would
builder reports
and
labordtl
are a high
routings that
runs
the worst
> offenders.
> Patrick Winter
in this
production
incorporate
must
access.
Builder
1/10/2005
must have
Builder and
> Yahoo! Groups Links
