Thank you soooooo much - I will give it a try.
You are the MAN!
DaveO
You are the MAN!
DaveO
--- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> Here's an example that should get you started. You'll have to add a reference to Epicor.Mfg.BO.Part and Epicor.Mfg.IF.IPart
> Public Class Form1
> Â Â Â Dim _partDS As PartListDataSet
> Â Â Â Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
> Â Â Â Â Â Â Â Using epiSession As New Session("manager", "manager", "AppServerDC://", Session.LicenseType.Default)
> Â Â Â Â Â Â Â Â Â Â Â Dim _part As New Part(epiSession.ConnectionPool)
> Â Â Â Â Â Â Â Â Â Â Â _partDS = _part.GetList("Company='100' AND TypeCode='M'", 0, 0, False)
> Â Â Â Â Â Â Â Â Â Â Â cboParts.ValueMember = "PartNum"
> Â Â Â Â Â Â Â Â Â Â Â cboParts.DataSource = _partDS.Tables(0)
> Â Â Â Â Â Â Â Â Â Â Â cboParts.DropDownStyle = ComboBoxStyle.DropDownList
> Â Â Â Â Â Â Â Â Â Â Â cboParts.DrawMode = DrawMode.OwnerDrawFixed
> Â Â Â Â Â Â Â End Using
> Â Â Â End Sub
> Â Â Â Private Sub cboParts_DrawItem(sender As Object, e As System.Windows.Forms.DrawItemEventArgs) Handles cboParts.DrawItem
> Â Â Â Â Â Â Â e.DrawBackground()
> Â Â Â Â Â Â Â If e.Index >= 0 Then
> Â Â Â Â Â Â Â Â Â Â Â Using Brush As Brush = New SolidBrush(e.ForeColor)
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â e.Graphics.DrawString(_partDS.Tables(0).Rows(e.Index)("PartNum").ToString(), e.Font, Brush, e.Bounds.Left + 1, e.Bounds.Top)
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â e.Graphics.DrawString(_partDS.Tables(0).Rows(e.Index)("PartDescription").ToString(), e.Font, Brush, e.Bounds.Left + 50, e.Bounds.Top)
> Â Â Â Â Â Â Â Â Â Â Â End Using
> Â Â Â Â Â Â Â End If
> Â Â Â End Sub
> End Class
> From: DaveO <daveolender@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, December 27, 2012 3:27 PM
> Subject: [Vantage] Re: Visual Studio 2010 Web service example
> I was thinking as a start (I'm a total newbie) a drop down list of manufactured parts. The drop down would show the part number and description and return just the part number.
> I was thinking of using the Epicor.Mfg.BO.Part as an external reference and I would guess the GetList method?
> Any suggestions,
> DaveO
> --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > Dave,
> > What are you trying to return a dataset of?
> >Â From: DaveO <daveolender@>
> > Sent: Thursday, December 27, 2012 12:54 PM
> >Â
> > Thank you Mr. Mark: I found your example in the files section. I modified the Close() call to Dispose() and it compiled and appears to login. Thank you so much. - This does look easier.
> > Now I just need to figure out how to work with, return data sets.
> > Thanks again,
> > DaveO
> > --- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@> wrote:
> > > Hi Dave,
> > > If you're writing programs that communicate directly with Epicor is VS,
> > > skip the web services and use the business objects directly. It's much
> > > faster. There are example programs in the Files section of the newsgroup.
> > > Mark W
> > > On Monday, December 24, 2012, DaveO wrote:
> > > > I have been trying to setup my Visual Studio to experiment using web
> > > > services to connect to the Epicor DB and I am running into a number or
> > > > technical stumbling blocks.
> > > > I am NOT a programmer, but I have done a fair amount of VBA and ASP
> > > > programming.
> > > > For instance, The developer example in the web services folder directs me
> > > > to "change the base class that the proxy inherits from" however I am unable
> > > > to find the Proxy Class they are referencing.
> > > > Just wondering if anyone has a VS 2010 small project they would be willing
> > > > to share that I could use as a guide to using Web Services?
> > > > Thank you for any help you can offer me,
> > > > Dave Olender
> > > >Â
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
