Vntg 8.0 client
You're right, there is no reason not to install in the prescribed order.
Of Todd Hofert
Sent: Friday, January 19, 2007 8:52 AM
Subject: RE: [Vantage] Vntg 8.0 client
Chris,
You are right on with Crystal, however my experience (8.03) has been
that installing the client prior to .Net works most of the time but not
all of the time. I have resigned myself to install them in the
recommended order which has worked 100% of the time in my environment.
Todd
Behalf
Of Chris Clunn
Sent: Friday, January 19, 2007 8:44 AM
You can copy the whole CD to your shared drive (.Net, Crystal, Client
install) and run it from anywhere in your network. Although for best
performance, you will probably want to get the latest Crystal Runtime XI
R2, which is available on the Epicor website. This is just the runtime
engine so you can still edit or create custom reports with the full
version of Crystal 10 (if that's what you have).
I don't think the order is that critical as long as the .Net is loaded
before you run Vantage. Vantage will also run just fine without Crystal
loaded although you won't have half your reports available until you do.
Behalf
Of Todd Hofert
Sent: Thursday, January 18, 2007 4:30 PM
You can share a DVD Drive and run it from the share just like from the
network. Or you can copy it to the server.
Either way. Key is that dotnet and the dotnet service pack is installed
as well as the client.
Todd
<mailto:vantage%40yahoogroups.com> on
behalf of Dunn, Nancy
Sent: Thu 1/18/2007 4:15 PM
That would be better then running around with a CD.
Thanks Paul.
<mailto:pblais%40lavignemfg.com>
<mailto:pblais%40lavignemfg.com> <mailto:pblais%40lavignemfg.com> ]
Sent: Thursday, January 18, 2007 3:48 PM
You can also copy all that down to the server from the DVD and run them
off the server for each client.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On
Behalf Of Dunn, Nancy
Sent: Thursday, January 18, 2007 3:13 PM
Okay, I did that on the server, but I didn't think I needed them on the
client.
I will give it a try.
Thanks Todd, you are aways a help.
Nancy
<mailto:todd%40spartangraphics.com>
<mailto:todd%40spartangraphics.com> <mailto:todd%40spartangraphics.com>
<mailto:todd%40spartangraphics.com> ]
Sent: Thursday, January 18, 2007 3:07 PM
Nancy,
You have to run it from the CD so you get the options to install Dot Net
1.1, the Dot Net SP1, the Crystal Runtime files and then finally the
client. You have to do them all in that order. Client should work then.
Todd
Sent: Thursday, January 18, 2007 2:53 PM
Subject: [Vantage] Vntg 8.0 client
I am having problems with installing the Vantage client on a PC.
The client installed on the server works just fine. The DB, Apps
servers, etc are running.
I think I have all the rights for the users okay.
I have tried the full client install from the CD and the minimal client
install from the CD. I think I should be installing the clients from the
server, but I can't find anything on how to do this.
I am so used to the older versions of client installs - there was a
Client install program on the server.
What am I doing wrong?
Nancy
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
This is an e-mail from Saab Barracuda LLC. It is for the intended
recipient only and may contain confidential and privileged information.
No one else may read, print, store, copy, forward or act in reliance on
it or its attachments. If you are not the intended recipient, please
return this message to the sender and delete the message and any
attachments from your computer. Your cooperation is appreciated.
This message has been scanned by F-Secure Anti-Virus for Microsoft
Exchange.
For more information, connect to http://www.f-secure.com/
<http://www.f-secure.com/>
This is an e-mail from Saab Barracuda LLC. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
This message has been scanned by F-Secure Anti-Virus for Microsoft Exchange.
the server, but I can't find anything on how to do this.
Nancy
Nancy,
Todd
Of Dunn, Nancy
Nancy
client.
Nancy
Nancy,
Todd
Nancy
Of Dunn, Nancy
client.
Nancy
Nancy,
Todd
Nancy
Thanks Paul.
client.
Nancy
Nancy,
Todd
Nancy
You can share a DVD Drive and run it from the share just like from the network. Or you can copy it to the server.
Either way. Key is that dotnet and the dotnet service pack is installed as well as the client.
Todd
From: vantage@yahoogroups.com on behalf of Dunn, Nancy
Thanks Paul.
From: Paul V. Blais [mailto:pblais@... <mailto:pblais%40lavignemfg.com> ]
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
client.
Nancy
From: Todd Hofert [mailto:todd@... <mailto:todd%40spartangraphics.com>
Nancy,
Todd
Nancy
Of Todd Hofert
Todd
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
Thanks Paul.
On
client.
Nancy
Nancy,
Todd
Nancy
Chris,
Todd
Of Chris Clunn
Behalf
Of Todd Hofert
Todd
Thanks Paul.
On
client.
Nancy
Nancy,
Todd
Nancy
Exchange.
