Hi All,
after running the patch pa400814 the start of VantageBasic Forms
Designer ends up with a bigger editable window and this error
message: "Unable to set the VIRTUAL-HEIGHT-PIXELS of the WINDOW
widget too small to contain all visible widgets.(4070)"
After hitting "ok" twice the window reduces to the size we had before
the patch and sits there with an continues hourglass.
I had a similar problem already with other windows that I get a
scroll-bar on the right and bottom side of the Vantage window and
also this widget error message.
I think it has to do with the resolution the way my monitor is setup:
1280 x 1024
Any ideas whats going on ?
Hendrik
1280 x 1024
Hendrik
