My apologies. I read further and saw where you were inquiring about attachments not crystal reports
Sent from my Verizon Wireless BlackBerry
Sender: vantage@yahoogroups.com
Date: Thu, 23 Sep 2010 16:18:44
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: Re: [Vantage] Watermarks on attached documets in Epicor
Simply create a huge text box with a large font and a very light grey color in it's own Detail section then in section expert mark the detail section right before it as Underlay
folloWing section
Then you can conditionally supress that text box
That's how the POform.rpt is done with Changed Order" go take a look
Date: Thu, 23 Sep 2010 12:05:44
Subject: RE: [Vantage] Watermarks on attached documets in Epicor
One idea would be to use a tool like this:
http://www.a-pdf.com/watermark/index.htm
It has a command-line tool, so you could either integrate this at the
time of attachment via a BAM, watching XFileAttach, with a 4GL program.
Basically you'd just call this from your custom code to stamp the file
that's been attached in Vantage. You could presumably do some filtering
on the BAM based on your needs.
-bws
Of Mark Wonsil
Sent: Thursday, September 23, 2010 11:57 AM
viweing documents from Epicor. I added a watermark on a PDF file in
Adobe Acrobad, which made the file grow in size, which was not too bad,
but when tried to print the size jumped to 20MB.
stage. You could create a new printer with the "Controlled Copy"
watermark turned on and then use that printer for controlled
documents. The con: you can't make people to use that printer...
Mark W.
folloWing section
-bws
Of Mark Wonsil
> Has anyone implemented a watermarking attached documents in Epicor? Wewould like to have "Controlled Copy" to show or print when we are
> Any ideas?Many modern print drivers allow you to add a watermark at the printing
Mark W.
