Not true... WSE will work comfortably in VS2010 / .net 4.0... 3.0/3.5 are only extensions to 2.0. It is a matter of how you create the pages in VS using the wizards. It will try to push you in the WCF path.
--- In vantage@yahoogroups.com, "Tim Vonderhaar" <tvonderhaar@...> wrote:
> I went through the very same question you are asking. You can actually install and use both, but as the others have said, WCF is the way to go if you are starting fresh. I believe there is also a framework limitation with WSE. I think 2.0 is the highest it will support.
> --- In vantage@yahoogroups.com, Rob Bucek <rbucek@> wrote:
> > All,
> > We are finally installing our test environment for 9.05... my IT director is asking me about WSE vs WCF and im like WTF? Not very familiar with those concepts, the destructions say we can continue with WSE but should I consider converting to WCF? What is the difference between the two? If I don't convert, what opportunities or functionality am I giving up? Thanks in advance for your input.
> > Rob Bucek
> > Production Control Manager
> > PH: (715) 284-5376 ext 311
> > Mobile: (715)896-0590
> > FAX: (715)284-4084
> > [Description: cid:1.234354861@]<http://www.dsmfg.com/>
> > (Click the logo to view our site)<http://www.dsmfg.com/>
