I would use the Web Services unless your transaction volume is just too
high. That way if you put BPM or Data Directives or something on those
fields later, it won't be an issue.
On Mon, Feb 14, 2011 at 11:09 AM, mmcwilliams22 <mmcwilliams22@...>wrote:
> So as long as it is just UD fields no sense in using the Web Service is
> what I am hearing?
> --- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> > ODBC does not check any business rules while Web Services ensure that
> > everything is done properly.
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@...
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <
> http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <
> http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > *Quis custodiet ipsos custodes?*
> > On Mon, Feb 14, 2011 at 11:04 AM, mmcwilliams22 <mmcwilliams22@
> ...>wrote:
> > > Any advantage of using Web Services to update UD fields on the JobHead
> with
> > > WebServices instead of ODBC?
> > > I just need to create an app that I can pull in some data and allow the
> > > user to mass update JobHead.ShortChar01 and JobHead.Number01
