First of all ensure that .net 2.0 is installed. Then make sure that the Vantage Services are using .net 2.0 and not .net 1.1 if both are installed. I don’t remember how to check this since I don’t have .net 1.1 installed anymore.
The above is assuming that you have installed the web services on the vantage server. There is really nothing to configure in IIS other than it needs to be installed. The installation of the web services sets up the virtual directory, etc. Make sure that when you install the Web Services that you used the correct progress server and port number since it does not default to the correct port. The server is normally just localhost and the port should be the port number used by the mfgsys803 appserver. For me it is 8301. If you do have it wrong just correct it and then restart IIS.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Heiti Kruusmaa
Sent: Thursday, August 07, 2008 5:23 PM
Subject: [Vantage] web services
i installed service connect in order to import data into vantage.....but
problem is that web services are not running, it is my second
installation on first one all worked well , also compared configurations
but still no luck...
i have feeling it has something to to with IIS settings or setup...
has anyone worked with web services and can give some pointers how to
trouble shoot this problem ?
many thanks
heiti
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
many thanks
heiti
DISCLAIMER:
