Unsure how to explain this but I’m seeing some weird issues with the Epicor client.
Both in production and pilot. I do run it on a VM on my machine but I’ve never had issues before. I uninstalled and reinstalled and still have the same issues.
Basically, if I open any window, like Order Entry, then I try to search for an order, it will pull up the orders but then I can’t select one. And then if I try to close the search window, it won’t close. I can move the window but nothing else. I end up having to force quit Epicor.
Weird thing is, I tried this on another VM (Azure - not local) and I have the same issue.
It’s Kinect but the local client, not the browser version.
I doubt it’s the machines/AV software. The local VM is a fairly new install and the Azure VM is like a few days old with only local network access. Everything works on both machines. It’s just Epicor that is the issue. The Azure VM doesn’t have an AV/Malware software other than the Windows one.
Have you tried personalization purge and/or deleting the cache directory? I’ve seen weird issues for our users when they have two personalizations on the same form as well as some occasions when their C:\ProgramData\Epicor\ folder contains corrupted files
