Weird Request to display other than Message Alert Box
Patrick,
Look into having Vantage bring it into the copy buffer (don't remember
the syntax) but your .p can populate the copy paste buffer without
displaying the results in a box. Then they just paste in the field you
want. The other option I would suggest is populate a screen value of a
field on the VBForm. Have them copy it from there (gives historical
look back and reporting options as well).
Good luck.
Aaron Hoyt
Hittite Microwave Corporation
Sent: Tuesday, March 09, 2004 4:56 PM
Subject: [Vantage] Weird Request to display other than Message Alert
Box.
All,
If I create a .p script file to run on a VBFORM button to multiply two
fields then display the results, is their another option other than a
"Message Alert Box" that is simple to code in. What I need is the
ability to
cut and paste the calculated number.
Example: Material Surcharge
VBFORM button on the InvcDtl line to Multiply the pieces * the part
weight *
the material surcharge, cut the number and paste it in when next adding
a
misc charge.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.20.322, Progress 9.1D, Windows 2003 Server
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cjn1vcv/M=274551.4550177.5761904.1261774/D=eg
roupweb/S=1705007183:HM/EXP=1078955734/A=2019528/R=2/SIG=141g7ntds/*http
:/ad.doubleclick.net/jump/N3349.yahoo1/B1282054.27;abr=!ie4;abr=!ie5;sz=
300x250;code=18634;dcopt=rcl;ord=1078869334928760?>
Click Here
<http://ad.doubleclick.net/ad/N3349.yahoo1/B1282054.27;abr=!ie4;abr=!ie5
;sz=300x250;code=18634;dcopt=rcl;ord=1078869334928760?> Click Here
<http://us.adserver.yahoo.com/l?M=274551.4550177.5761904.1261774/D=egrou
pweb/S=:HM/A=2019528/rand=458641355>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
All,
"Message Alert Box" that is simple to code in. What I need is the ability to
VBFORM button on the InvcDtl line to Multiply the pieces * the part weight *
the material surcharge, cut the number and paste it in when next adding a
misc charge.
Patrick Winter
