Bartender is great, but it can get really expensive in the licensing.
It's based on number of printers printed to, but the catch is that it
issues licensing based on hostname. For example if one user prints to it
via a print server say \\printserv\hp1080 <file:///\\printserv\hp1080>
and then epicor prints to it directly (the best way to go vs UNC) by ip
address \\192.0.0.25\ <file:///\\192.0.0.25\> it will absorb two licenses
even though it's one physical printer. So you have to think pretty hard
about how and when bartender will be printing. Reprinting labels is
inevitable which is triggered from some ones local machine.
The other hitch is you can really only print one label format at a time.
Example being we have different customers that require custom label
formats per customer. Impossible to do this just between Epicor and
Bartender. You have to have some middleware that can determine which
label format needs to be used. I for example have a UD field attached to
parts that specify the filename of the label format to use for that part
specifically. After the bartender file leaves Epicor and is created a VB
script picks that file up find the UD field and replaced the header of the
bartender file (this tells bartender which format to use) and then sends
the newly saved file to bartender. A mouth full I know...
Aside from that I fully would recommend bartender. The program is super
easy to use.
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Joe Rojas
Sent: Wednesday, August 15, 2012 8:58 AM
To:
Subject: [Vantage] What do others use for labeling?
Hi All,
We've been using make-shift solutions for labeling but our customers
continue to demand more.
It's time for us to move to a "real" labeling solution like Bartender.
It looks like Epicor has some kind of interface with Bartender but I
wanted to see what others are using.
Other than all the standard functionality that you'd expect in a
labeling software, the only other real technical requirement we'd like
is to be able to have labels automatically print out when certain events
happen in Epicor.
Is Bartender the way to go or is there another/better software out there
that you'd recommend?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us
about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the
named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
