The EpiBinding says in the User Account Maintenance form: User.CanImpersonate but when I query the erp.userfile I do not see any column with impersonate in it or anything close?
Please help!
Richard
Please help!
Richard
The table you want is Ice.SysUserFile. The field is in there.
Like Nate said, there are two UserFiles. The “secured” one is Ice.SysUserFile. Erp.UserFile is a shadow copy with the security information stripped out.
As we get more into Kinetic, we’ll want to do the same thing the browser is doing and use REST (Ice.BO.UserFileSvc) to get content when appropriate. Here’s the layout of the Ice.UserFile.Tableset returned in a REST call. The nice thing here is it does any VIEWs for you that you’d have to do manually in a query. Also, proper security is applied.
Ice.Tablesets.UserFileRow{
UserID string
User ID
Name string
User Name
Address1 string
First address line
Address2 string
Second address line
City string
City portion of the address
State string
State portion of the address
ZIP string
Postal code or zip code portion of the address
Country string
Country portion of the address
OfficePhone string
Office phone number
Phone string
Home phone number
EMailAddress string
User's e-mail address.
UserDisabled boolean
Indicates if the user account has been disabled (turned off).
SecurityMgr boolean
Indicates that the user account has security maintenance privileges.
CanChangeSaveSettings boolean
Allow user to change save settings
Save settings
CurComp string
Represents the current or Last company logged on to by the user. This is used as default next time they log on.
PwdLastChanged string($date-time)
Date that the password was last changed.
PwdExpiresDays integer($int32)
Password expires x days after the password has been changed. Zero means the password does not automatically expire.
PwdExpires string($date-time)
The date that the user account password expires.
PwdGrace integer($int32)
The number of remaining grace logins.
GroupList string
List of security groups the user belongs to.
CompList string
List of companies the user has access to.
ViewFavoriteBar boolean
Enable Favorite Bar
ViewStatusBar boolean
Enable Status Bar
WinX integer($int32)
Main menu X-position
WinY integer($int32)
Main menu Y-position
CurFolderSeq integer($int32)
Sequence number of the folder in focus
CurMenuID string
MM=module, XX=MN,UP,LS,PC, and ZZZZ = number.
WinWidth integer($int32)
Main menu width
WinHeight integer($int32)
Main menu height
DispTips boolean
Indicates if the user wants tips to be displayed during logon.
CanChangePassword boolean
Whether the user can change their password.
LangNameID string
Language ID
LastGraphType string
The last type of Graph (Bar, 3D Bar, Line, etc.) used in the Schedule Load Graph program.
UseInternalWebBrowser boolean
Indicates that the internal web browser should be used instead of using the OS registered browser.
AllowMultipleSessions boolean
Allow user to start multiple sessions at the same time.
WebUser boolean
Indicates that the user has Web interface privileges. When this is turned on, the write trigger maintains certain fields in the WebUser table. If this is never turned on, a corresponding WebUser doesn't exist. If this has been on, and is now turned off, the WebUser record is set to disabled, but not deleted.
ListViewMode integer($int32)
This property determines the viewing mode of the ListView object. The ListView object supports viewing items in four different modes: Icon(0),SmallIcon(1), List(2) and Report(3). Only 0 1 and 3 are used
CanMaintainFavQueries boolean
Whether the user can add/maintain Dashboard Queries on the favorites bar.
CanMaintainFavURLs boolean
Whether the user can add/maintain Dashboard URLs on the favorites bar.
CanMaintainFavPrograms boolean
Whether the user can add/maintain Windows Programs on the favorites bar.
CanCustomize boolean
Whether the user can access customization screens.
ViewTreeOnly integer($int32)
Whether to display the TreeView alone.
Timeout integer($int32)
Time Out
CanPersonalize boolean
Whether the user can personalize.
CanTranslate boolean
Whether the user can translate.
CanEditCompAnnotations boolean
Can this user edit Company level Help Annotations
CanEditUserAnnotations boolean
Can this user edit user level Help Annotations
CanEditHelpLinks string
Does this user get access to the HelpLink Editor
AutoStartMonitor boolean
Does this user want the Monitor to Started when they log in. (replaces Config Setting)
MonitorPollingInterval integer($int32)
How frequently (expressed as secounds) the Monitor will poll for results
FormOpenMode string
Default form open behavior (Nil, Auto'S'earch, Auto'P'opulate) - (Replaces Config Setting)
EntConType string
Enterprise Connection Type, Determines how the UI Behaves when Session information is changed and UI forms are already present (Nil, 'S'ingleSession, 'M'ultiSession) (Replaces Config Setting)
DashboardDeveloper boolean
Allow user to open dashboards in developer mode
CanDesignQSearch boolean
Allow user to design quick searches
RequireSso boolean
Whether single sign-on (SSO) is required to log on.
Select this check box to indicate that this user has to use his/her operating system (Windows, Unix, and so on) logon information as the logon for Vantage.
Single Sign-On (SSO) is functionality that allows users to sign on (log in) to Vantage using the Login IDs and Passwords they use to log into their computer's operating system (for example Windows, Unix, Linux and so on). In other words, if SSO is enabled, users will not be presented with a Logon window when they click their Vantage icon; they will be taken directly to the application's main menu.
ViewStatusPanelUserID boolean
Show User ID in status panel
ViewStatusPanelLanguage boolean
Show language in status panel
ViewStatusPanelCompany boolean
Show current company in status panel
ViewStatusPanelPlant boolean
Show current Site in status panel
ViewStatusPanelServer boolean
Show server name in status panel
ViewStatusPanelWorkstationID boolean
Show workstation in status panel
DomainName string
Name of the operating system domain into which this users logs in. Used when Require Single Sign on is enabled.
BPMAdvancedUser boolean
Determines whether the user is allowed to use advanced development features of Business Process Management. The freeform editor requires knowledge of Progress 4GL programming and specific method operational working. Typically freeform options are used by Epicor custom programming or experienced programmers for advanced techniques not available through the wizard-like interface.
MaxGroupsFavorites integer($int32)
Maximum number of favorite bar groups
MaxGroupsSystemMenu integer($int32)
Maximum number of system menus
OSUserID string
Operating system user ID.
CanTheme boolean
Allow user to create themes
FormatCulture string
Culture format
CanUseEntSearch boolean
yes = the user can use enterprise searches
CanAccEpiEverywhere boolean
Allow access to EWA
CanAcessMobile boolean
Allow Acess to Mobile Office
StartMenuClient string
Initial start Menu for the Client
StartMenuEWA string
Initial Start Menu ID for EWA
StartMenuMobile string
Initial Start Menu ID for Mobile
AdvBAQRights boolean
Allow advanced BAQ designer rights
SecurityAccessOnly boolean
Defines isthe uesr has Security Access Only
SolutionMgrCreate boolean
Defines if is user can create a Solution using the Solution Manager
SolutionMgrInstall boolean
Defines if a user can install Solutions using the Solution Manager
EntSearchURL string
Enterprise Search URL
CanMaintQuickSearch boolean
Whether the user can add/maintain Quick Searches.
UseDefaultEntSearch boolean
Use Default Enterprise Search
UserAccessOnly boolean
UserAccessOnly
GlbCompSM boolean
Global Company Security Manager
Allows a user on a Isolated-Company system to behave like a user on a regular system. Can be allowed to login to multiple companies and can apply changes that affect all companies. Used to maintain menus and global customizations or security.
BAQXCompany boolean
BAQXCompany
LastLogOnAttempt string($date-time)
LastLogOnAttempt
CanImpersonate boolean
CanImpersonate
ViewStatusPanelSolutionID boolean
CanMaintPredictiveSearch boolean
ThemeID string
ThemeID
DisableTheming boolean
DisableTheming
SysRevID integer($int64)
example: 0
Revision identifier for this row. It is incremented upon each write.
SysRowID string($uuid)
example: 00000000-0000-0000-0000-000000000000
Unique identifier for this row. The value is a GUID.
CanPublishLayout boolean
CanPublishLayout
DefaultLayoutID string
DefaultLayoutID
CanViewDocStar boolean
CanViewDocStar
PwdChangeRequestOn string($date-time)
PwdChangeRequestOn
ExternalIdentity string
ExternalIdentity
SSRSReportDesigner boolean
SSRSReportDesigner
DefaultHomepageLayoutID string
AccessScopeID string
AccessScopeID
IoTUser boolean
IoTUser
IoTAdministrator boolean
IoTAdministrator
DMTUser boolean
DMTUser
EVAUser boolean
EVAUser
DefaultFormType string
DefaultFormType
HideKineticToast boolean
HideKineticToast
AdvancedConfiguratorUser boolean
CanOverrideAllocPart boolean
ClearPassword boolean
If yes, the user will be able to enter a blank password and still get the prompt for new password.
ExpirePassword boolean
If yes, the user will be forced to enter his or her current password before he or she will be prompted for the new password.
FailedAttempts integer($int32)
IntegrationAccount boolean
LockedOut boolean
LockedOutUntil string($date-time)
MobilePassword string
PasswordBlank boolean
set passwrod to blank
PasswordEmail string
E-mail to send new password to
ShpTrackerIntMinute integer($int32)
How often (in minutes) the user wants their shop tracker displays will be automatically refreshed.
UpdateWarning string
UseCompression boolean
AllowReq boolean
Whether the user can be referenced as the requestor on a PO Requisition.
LangNameIDDescription string
BitFlag integer($int32)
RowMod string
RowMod
Number01 number($double)
example: 0
UD_SysRevID string($byte)
example:
111
