Whatsnew52.pdf
I origanally downloaded the whatsnew52.pdf on 7/11/2002 it was 120kb.
Today I downloaded the same document at 127kb.
I saved both to text and ran thru a compare program. The new file has over a
page worth of text added. Many areas have been reworded.
One example of text added:
VB Form Mapping
A new program, VB FormMap, can assign VB Form tables during the Get Details
process.
Use this program to assign VB Form tables in the Engineering Workbench to
the
manufacturing details VB Forms in the Part master file.
For example, you can map the ECOMtl VB form (the source) to the PartMtl VB
form (the
target), and then map the PartMtl VB form (the source) to the JobMtl VB form
(the target).
As a result of the assignments, the value can be entered once in the ECOMtl
VB form, and
it is carried through the revision check-in fromthe EngineeringWorkbench
through the Get
Details process in Job Entry to the job's material automatically.
{bmc imppoint.bmp} The VB form fields must be of the same data type and
control type.
For example, a checkbox cannot be mapped to a character fill-in field.
To bad the documents don't have a revision number.
Patrick Winter
