epicor version 9.05.701
Hi,
Is there any chance Epicor MES could be set to the correct time. It is about 2.5 minutes out.
Hi,
it gets the time from the server, not the client, you’ll need to resolve your server/client sync in your OS environment.
Thank you.
Could you walk me through the steps on the server side?
Rowley it should be just whatever the Windows Server’s time is. RDP into the server and on the bottom right of the taskbar right click on the time and you will find Adjust date/time
If your Server is in China it would be chinese time however in Epicor under Site or Company Maintenance you can set that Epicor’s timezone and it will convert the time to the proper timezone.
