I could not find the Multi-Resource Scheduling Board under Scheduling. Anyone know if this is still available or where it is located? Also is there a way to add additional columns into the display board?
If you haven’t licensed APS, that won’t be available to you.
Ok, thanks. I see it the Demo database but not in the Test. How much effort would it be to add Multi-Resouce without being licensed APS using just the Resource Scheduling Board. Basically add the functionality to view multi-resource on the Resource Scheduling Board.
If your demo and test are using the same license it should be there for both. Can you find it using the Menu Search?
Sorry in the Customer’s Test database and not the Demo which are two different instances and licensing.
