The report XML can usually found on the server share, a path something like this:
\\SERVERNAME\Epicor\mfgsysdata\Reports\USERID
BTW... when you print/preview your report you can specify how long the XML file will be retained in your report folder with the "Archive Period" setting on the report form
---In vantage@yahoogroups.com, <clederer@...> wrote:I'm trying to export a canned report into Crystal Reports and edit it through Crystal. I need to use the original data connection from the original report. Right now I'm not be able to preview it from within Crystal. I think is because I need to find where the sample data is. Once I can get some sample data by running the report, I can find where it saves the XML files. I'm not sure where it is, except I'm fairly certain it is on the server somewhere.
