Where Used - Crystal Report Epicor 9.04.506b
I have, but I did a fair amount of work to get to it.
I'm on 8.03.408B MSSQL.
To accomplish what I wanted to do, I wrote a C#/.NET program that
takes a list of top-level manufactured parts with a BOM, and for each
part, explode the BOM and capture some details. I process this data and
store it in UD03. UD03.Key1 contains the top-level partnum. UD03.Key3
contains the sub-component partnum. I call this program BOMCache since
is creates a cache of exploded BOM info. This info doesn't change that
quickly, so refreshing the BOMCache nightly seems reasonable.
I can then use this in table joins to bring in, for a purchased part,
the top-level assemblies that part is used in. I can then do grouping
in Crystal and hide detail sections, etc. depending on how I've
constructed my queries to do some powerful analysis.
This only works in MSSQL since you can use common table expression
(CTE) queries to deal with hierarchical data structures.
I'm happy to share the source code if someone wants it. The whole
thing is configuration driven via a config.xml file.
-bws
Of advantage@...
Sent: Monday, October 25, 2010 11:41 AM
Subject: [Vantage] Where Used - Crystal Report Epicor 9.04.506b
Has any one created a Where-Used Report in Crystal?
Hi Folks,
I have done this 100's of time on other other forms, but when I go to add a test box to the Job Entry form, assign it to Job Head\Short Char01, save and reopen it's just grey. Enabled = True. I then changed it to JobHead\Char01 and same result - is this a bug?
Regards,
Michael
Vantage 8.03.406
Michael,
You're beating your head against the Vantage UI business logic. This
happens on other forms, too, where the UI is locked down not permitting
changes to Jobs that have been Released or Closed, etc. Sales Orders
and Quotes, among others, exhibit the same behavior and I've had to do
alternate "back door" approaches when I need to do this.
Of michael.hutcheson@...
Sent: Monday, October 25, 2010 10:59 AM
Subject: [Vantage] Unable to customise Job Entry form
Hi Folks,
Regards,
Michael
Vantage 8.03.406
Is EpiKeyField set to true?
Hi Folks,
Regards,
Michael
Vantage 8.03.406
How do I get round it? All I want is a text box linked to shortchar01........
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> Michael,
> Hi Folks,
> Regards,
> Michael
> Vantage 8.03.406
This has solved it, thank you. What exactly does the EpiKeyField do?
> Hi Folks,
> Regards,
> Michael
> Vantage 8.03.406
Ahh... yea, that sometimes will work. It links it to the business logic
of the form. It's been hit or miss in different patch levels of .400
for me.
Sent: Monday, October 25, 2010 11:15 AM
Subject: [Vantage] Re: Unable to customise Job Entry form
Behalf
> Hi Folks,
> Regards,
> Michael
> Vantage 8.03.406
Hi Michael,
I have no idea what it does. I was told to turn it on when I did my
first customization and I've done it ever since. It makes no sense to
me because it obviously is not a "key" field that I'm customizing.
Regards,
Linda
Behalf
> Hi Folks,
> Regards,
> Michael
> Vantage 8.03.406
You have to love Vantage....
> Hi Michael,
> Regards,
> Linda
> Behalf
> > Hi Folks,
> > Regards,
> > Michael
> > Vantage 8.03.406
Setting the EpiKeyField to true makes the field available BEFORE a
record is returned e.g. it is needed as part of the record key to get
the data. If this is false, the field won't become available until you
have selected a record.
Of Linda Lowney
Sent: Monday, October 25, 2010 12:26 PM
Subject: RE: [Vantage] Re: Unable to customise Job Entry form
Hi Michael,
Regards,
Linda
Behalf
<mailto:michael.hutcheson%40rocketmail.com>
Behalf
> Hi Folks,
> Regards,
> Michael
> Vantage 8.03.406
