Not sure if this will help or not and I can't think of any of out parts off hand that have repeating lower level parts, but have you looked at the BOM Listing under Engineering reports? You can select a production quantity when you select a part and it will multiply out the quantities of all levels if you choose Indented Level. As I said I don't know if it would group everything under part number or if you'd be stuck adding manually to get part totals which I assume is what you're trying to get away from. Just thought I'd mention it in case it would be an option.
Sue
Sue
--- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@...> wrote:
> >Up One Level, Down One
> > Level, Job Material, and Job Assembly.
> Thanks Mark,
> We have one specific need. Maybe I've missed one that would do this?
> - Return the total required quantity of a part - per a top level system(s).
> The reports I've tried don't seem to get me there because of the scale of the "system" BOMs.
> There are multiple major sub assemblies that go 9 levels deep.
> A component part can be scattered all thru the system BOM structure.
> Purchasing wants/needs these quantities when new systems are being introduced and they are getting vendor quotes. (Often this means no jobs yet).
> When it comes up now, users start with the existing where used but then manually sort and add to get the final numbers they want.
> So I'm thinking something like the T-SQL CODE that Vassilis shared will be needed.
> I remember the legacy system had a custom indented where used report, and a process to regenerate the flat table used as the report source.
> Of course this is a Progress database....
> --- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@> wrote:
> > > We've tried the Where Used that comes with V8 but it isn't very useful for
> > > us.
> > > We need listings of the quantities for a top level system, where the part(s)
> > > will appear on multiple subassemblies and/or levels.
> > Just know that there is more than one Where Used programs in Epicor
> > (in 9.04, there are at least three) and each have different formats.
> > The one we use has five tabs: Part Where Used, Up One Level, Down One
> > Level, Job Material, and Job Assembly. Quite useful.
> > Mark W.
