Where's the ShipToContact info found?
Thanks very much Roel! That should be an enormous help! It's very close to our version (405), so it should be pretty accurate. I have a couple fields I need to find and this should shorten my sleuthing a lot!
Again, thank you very much for your help!!
Regards,
Kurt
--- In vantage@yahoogroups.com, Roel Martinez <rmartinez@...> wrote:
> I hear you Kurt!
> I don't remember how I converted to text 3 years ago, so I'll be uploading the DD in text format from May/2007 and PDF format from a couple of days ago into the public folders.
> Regards.
> Roel Martinez
> ERP Analyst
> SABRE TUBULAR STRUCTURES (tm)
> www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
> 8653 E. Hwy 67 | Alvarado, TX 76009
> Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Kurt
> Sent: Tuesday, September 14, 2010 2:48 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Where's the ShipToContact info found?
> Roel,
> Thank you very much for your suggestion! I am looking in to doing this. I'm just having problems with getting the DD to show up even though I have uber privileges. Just something goofy going on that I'm checking out. But that is definitely something that will save me a lot of time in the future! Sometimes Vantage loves to be cryptic and keeps things to itself. So, you need things like this!
> Thanks again!
> Regards,
> Kurt
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Roel Martinez <rmartinez@> wrote:
> > Good morning.
> > Kurt, I exported the Data Dictionary into a text-file and look for things in there.... In this case I would have done a search for "email" and found it (eventually) in CustCnt, as Sean and Michelle noted.
> > It is a 22 MB text file but it is very helpful, it even has the tables listed and described at the bottom. Some people prefer a PDF format, which will also provide these searching tools.
> > Regards.
> > Roel Martinez
> > ERP Analyst
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Kurt
> > Sent: Monday, September 13, 2010 9:15 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Thank you very much!! I think that should do it!
> > How do you find things like this that are in these Vantage views? Even if some are only created at run time, it would be nice to know, or be able to find the base tables.
> > Thanks again!!
> > Regards,
> > Kurt
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Sean McDaniel" <smcdaniel@> wrote:
> > > CustCnt is the table you want to look at.
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
> > > Of Kurt
> > > Sent: Monday, September 13, 2010 9:49 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] Where's the ShipToContact info found?
> > > Hi all,
> > > I have project where I need to know a ship to contact email address.
> > > What I am asked to use is on the Customer Maintenance - Ship To -
> > > Contacts - Detail tab and the txtEmail text box. But, there's two
> > > things. One, this text box, along with the related contact text boxes
> > > are bound to "ShipToContact". And two, the txtEmail text box shows no
> > > DataField. To make it more interesting, I can't find anything on the
> > > ShipToContact DataSource. Does anyone know where this data is kept? I've
> > > checked various other tables and the data doesn't match with what I have
> > > on the Customer Maintenance form and I can't find info on what is used
> > > to create this view. I appreciate any help you can offer!! Thanks very
> > > much!
> > > Regards,
> > > Kurt
Hi all,
I have project where I need to know a ship to contact email address. What I am asked to use is on the Customer Maintenance - Ship To - Contacts - Detail tab and the txtEmail text box. But, there's two things. One, this text box, along with the related contact text boxes are bound to "ShipToContact". And two, the txtEmail text box shows no DataField. To make it more interesting, I can't find anything on the ShipToContact DataSource. Does anyone know where this data is kept? I've checked various other tables and the data doesn't match with what I have on the Customer Maintenance form and I can't find info on what is used to create this view. I appreciate any help you can offer!! Thanks very much!
Regards,
Kurt
Of Kurt
Hi all,
much!
Regards,
Kurt
I think you can find this information in the custcnt table.
Michelle de la Vega
Program Director
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
USA
+1 513-716-6400 (office)
+1 513-382-3281 (mobile)
+1 513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01CB5329.4D16DE60]
Hi all,
Regards,
Kurt
Thanks again!!
Regards,
Kurt
> Of Kurt
> Hi all,
> much!
> Regards,
> Kurt
Thank you! I do appreciate your help!! Some things in Vantage still seem cryptic to me. One of these days I'll figure out how to find these things!
Regards,
Kurt
> Michelle de la Vega
> Program Director
> Cold Jet, LLC
> USA
> [cid:image001.jpg@...]
> Hi all,
> Regards,
> Kurt
Good morning.
Regards.
Roel Martinez
ERP Analyst
Thanks again!!
Regards,
Kurt
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Sean McDaniel" <smcdaniel@...> wrote:
> Of Kurt
> Hi all,
> much!
> Regards,
> Kurt
Roel,
Thanks again!
Regards,
Kurt
> Good morning.
> Regards.
> Roel Martinez
> ERP Analyst
> Thanks again!!
> Regards,
> Kurt
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Sean McDaniel" <smcdaniel@> wrote:
> > Of Kurt
> > Hi all,
> > much!
> > Regards,
> > Kurt
I hear you Kurt!
Regards.
Roel Martinez
ERP Analyst
Roel,
Thanks again!
Regards,
Kurt
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Roel Martinez <rmartinez@...> wrote:
> Good morning.
> Regards.
> Roel Martinez
> ERP Analyst
> Thanks again!!
> Regards,
> Kurt
> > Of Kurt
> > Hi all,
> > much!
> > Regards,
> > Kurt
