I’m sure something could be crafted on a pre-processing directive and a UD table for lookup upon Receipt.
Have a UD table with your Class and lookup the class and assign the warehouse appropriately via the BPM.
Sent: Friday, March 09, 2012 3:36 PM
Subject: RE: [Vantage] Whse and Bin defaults - able to set at a higher granularity than Plant Mnt lvl?
I was hoping for a way to set the defaults at a lower level, say inventory class (I checked this and could not find a warehouse setting).
I checked Part Maintenance and couldn't get any of the warehouse choices there to force a default at receipt entry.
I doesn't look like defaults can be set at any level other than Company Config or Plant Maint., but I wanted to see if I was missing anything.
Brian.
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Manasa Reddy
Sent: Friday, March 09, 2012 1:47 PM
To: mailto:vantage%40yahoogroups.com
Company Config --> Modules --> All Modules --> General (at least that is where it is in Vista)
M. Manasa Reddy
mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com><mailto:mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
Ex scientia, vera
From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Karen Schoenung
Sent: Friday, March 09, 2012 1:44 PM
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>
We have AMM, I don't see anything on Company Config - what tabs do I need to get to?
From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Manasa Reddy
Sent: Friday, March 09, 2012 1:38 PM
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
On company config you can if you have the AMM module, I think....
M. Manasa Reddy
mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
Ex scientia, vera
From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Karen Schoenung
Sent: Friday, March 09, 2012 1:34 PM
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Whse and Bin defaults - able to set at a higher granularity than Plant Mnt lvl?
A coworker would like me to post this question:
Does anyone know if there is a way to set the Warehouse and Bin defaults for Receiving parts and materials at a higher level of granularity than the Plant Maintenance level?
Brian
size=2 width="100%" align=center>
Total Control Panel
Login<https://asp.reflexion.net/login?domain=weldcoa.com>
To: mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: mailto:sentto-20369-108270-1331321637-manasa%3Dweldcoa.com%40returns.groups.yahoo.com<mailto:sentto-20369-108270-1331321637-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><mailto:sentto-20369-108270-1331321637-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><mailto:sentto-20369-108270-1331321637-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><https://asp.reflexion.net/address-properties?aID=584574055&domain=weldcoa.com>
Message Score: 1
High (60): Pass
My Spam Blocking Level: Low
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=584574055&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=584574055&domain=weldcoa.com> returns.groups.yahoo.com
This message was delivered because the content filter score did not exceed your filter level.
Total Control Panel
To: mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com><https://asp.reflexion.net/address-properties?aID=516126014&domain=weldcoa.com>
From: mailto:sentto-20369-108272-1331322230-manasa%3Dweldcoa.com%40returns.groups.yahoo.com<mailto:sentto-20369-108272-1331322230-manasa%3Dweldcoa.com%40returns.groups.yahoo.com><https://asp.reflexion.net/address-properties?aID=584587552&domain=weldcoa.com>
Message Score: 1
High (60): Pass
Medium (75): Pass
Low (90): Pass
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-address=1&rID=516126014&aID=584587552&domain=weldcoa.com> this sender
Block<https://asp.reflexion.net/FooterAction?ver=2&bl-sender-domain=1&rID=516126014&aID=584587552&domain=weldcoa.com> returns.groups.yahoo.com
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1913 / Virus Database: 2114/4860 - Release Date: 03/09/12
Brian.
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
M. Manasa Reddy
630.806.2000 x1515
Ex scientia, vera
Brian
Total Control Panel
Message Score: 1
High (60): Pass
Medium (75): Pass
Low (90): Pass
Total Control Panel
Message Score: 1
High (60): Pass
Medium (75): Pass
Low (90): Pass
